Squealing Sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brody_Vuko, Jan 22, 2018.
How to fix a squeal
  1. How to fix it
    50.0%
  2. Where the squeal is coming from
    100.0%
Multiple votes are allowed.
  1. Jan 22, 2018 at 11:41 AM
    Brody_Vuko
    Brody_Vuko [OP] New Member
    Brody
    2013 Toyota Tacoma Sr5
    None
    I have a 2013 Toyota Tacoma Sr5 And recently I’ve been hearing a sqealing sound. I’ve been trying to figure out where it’s coming from and it sounds like it’s from the engine. A couple days ago, I took my truck off-roading and it did great. Went through mud, sand, and water with no problems. I had been driving for about 10 miles on pavement and heard nothing until I pulled into my neighborhood and heard a loud squeal. When I heard this I came to a stop and it went away. After, I got up to about 20 mph and it started again. Once again I came to a stop and the sound stopped. A couple hours later I took it for a drive to see if it continued, which it did, but it was much quieter and started once I got to 35 mph. I don’t think it’s a belt because it only does it when I get around 30-35 mph. Any thought on what it could be and how I could fix it?
  2. Jan 22, 2018 at 11:44 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Pigglet got stuck in the wheel....
    Happened to me while driving thru mud.
    tcjacado and MotoEd like this.
  3. Jan 22, 2018 at 11:45 AM
    Brody_Vuko
    Brody
    None
    Did you hear it at all speeds or just when you got to a certain speed?
  4. Jan 22, 2018 at 11:48 AM
    tcjacado
    tcjacado Well-Known Member
    Going to most likely be one of the pulleys on the engine for the serpentine belt.
  5. Jan 22, 2018 at 11:51 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
    Probably just the muffler bearing got a little loose or needs to be lubed up. Looks like this download (1).jpg
    Or you can just buy a new one
    tcjacado and REDdawn6 like this.
  6. Jan 22, 2018 at 1:04 PM
    Brody_Vuko
    Brody
    None
    Thanks wise ass
    REDdawn6 likes this.
  7. Jan 22, 2018 at 2:19 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Were the windows closed ?? Not Joking.
  8. Jan 22, 2018 at 2:27 PM
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    I've been chasing a similar sound and replaced both idler pulleys with no luck. I was debating on trying the tensioner pulley next. I can only hear it if the windows are up and the radio turned off. It's pretty faint sounding and does not get louder with speed. If the truck is under 20 mph nothing, if the truck is still warming up nothing. Then you hear it. This all started after driving down a flooded road here going to help a friend out after hurricane Harvey hit.
  9. Jan 22, 2018 at 2:31 PM
    Canufixit
    New England
    Heater/AC Fan bearings ? Pressure in the cab changes with forward speed/wind being forced and compressed in the cab with the windows up. This changes the torque/speed of the fan. Hit the sweet spot - it squeaks. cover the cowl intake, Pull the fuse for the Fan and try it again. Note that you need to pull the fuse as sometimes the fan will not shut off but only stay on low to keep the cab free of CO/CO2. Some Vehicles may do this per my past readings .... not sure if this is true for Tacoma.
    tcjacado likes this.
  10. Jan 22, 2018 at 2:33 PM
    g35man
    League City, TX
    2012 MGM DC 4x4 OR
    will check that as well.
  11. Jan 22, 2018 at 3:20 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Grease the zerk fittings on the rear (and front if you have it) driveshafts
