Squealing/Squeaking while driving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JOGrady0309, Jan 1, 2019.
  1. Jan 1, 2019 at 8:10 AM
    JOGrady0309
    JOGrady0309 [OP] Member
    Josh
    2008 Blue Tacoma 4x4
    Bought the truck a couple weeks ago and it drives perfect. Only has 71k on it and I love it. Over the past week or so though I've noticed while driving at between 1500 and 2500 rpm there is a squealing/Squeaking no matter which gear I'm in. It doesnt affect how it drives or cause a rattle or vibration or anything but it's annoying/concerning. Any ideas?
  2. Jan 1, 2019 at 8:44 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You need a new serpentine belt and possibly a pulley/tensioner.
    Bigpat_ca likes this.
  3. Jan 1, 2019 at 8:46 AM
    JOGrady0309
    Josh
    Sorry, it should also be noted that it doesn't make the noise when in neutral and reving the engine. Only while in gear and driving.
  4. Jan 1, 2019 at 8:52 AM
    Jimmyh
    SC
    2012 Prerunner SR5
  5. Jan 1, 2019 at 8:53 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    It could still be the belt, but if not I got nothing.
  6. Jan 1, 2019 at 10:28 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Two more possibilities would be the water pump or maybe a u-joint.
    Freeheelbillie likes this.
  7. Jan 1, 2019 at 12:43 PM
    JOGrady0309
    Josh
    It's definitely a metallic sound and seems to come from the centerish of the truck
  8. Jan 1, 2019 at 12:54 PM
    buckhuntin-tacoma
    Dennis
    Quincy IL
    That would eliminate water pump,I would check the u-joints.
    MuddyJackson and Freeheelbillie like this.
  9. Jan 1, 2019 at 12:57 PM
    JOGrady0309
    Josh
    I plan on greasing all the fittings tomorrow at work and seeing if that helps. Like I said, its not affecting how the truck drives. I'll update with any new info. Thanks!
  10. Jan 4, 2019 at 1:31 AM
    JOGrady0309
    Josh
    Definitely a bad u-joint. Seems the seal on one side broke. Now to save money for the job. The u-joint is super cheap, the job is just so damn labor intensive
  11. Jan 4, 2019 at 1:49 PM
    sr52008tacoma
    sr52008tacoma Active Member
    Go to your dealer and complain about it. There is a extended service bulletin on u joints for certain years. You might get u joints free of charge
  12. Jan 4, 2019 at 2:17 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  13. Jan 4, 2019 at 2:36 PM
    JOGrady0309
    Josh
    For an 08 though?
  14. Jan 4, 2019 at 2:41 PM
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
    It's a little young for a Ujoint problem, but depending on where you live, it could have rusted or dried out. Give them a look, and grease if they're in tact, otherwise replace - They're like $25 from Autozone.
    I just did them on my 90' Chevy, which was having the same problem, but was accompanied by rattling until about 3k RPM. Ujoints were completely rusted out, and all of the needles from the roller bearings were missing.
  15. Jan 4, 2019 at 2:45 PM
    JOGrady0309
    Josh
    Considering I paid $19 for the u-joint and the labor charge is $300, its pretty labor intensive
  16. Jan 4, 2019 at 2:46 PM
    JOGrady0309
    Josh
    Seems the seal is cracked on one side. Getting it taken care of tomorrow. Thanks!
    mud[QUOTED] likes this.
  17. Jan 4, 2019 at 3:35 PM
    buckhuntin-tacoma
    Dennis
    Quincy IL
    $300 labor :eek: You need to find a different mechanic!!
  18. Jan 4, 2019 at 4:05 PM
    JOGrady0309
    Josh
    In the process of this thread tonight I figured out my buddy is gonna do it. Just gotta get him a case of twisted tea. And he says it'll take 45 minutes. Not too shabby!
  19. Jan 4, 2019 at 4:41 PM
    mud
    mud Djentleman
    SoCal
    :cheers:
