Squealing when i turn my steering wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rktacoma, Oct 6, 2012.
  1. Oct 6, 2012 at 9:01 PM
    rktacoma
    rktacoma [OP] Member
    08 tacoma 6" lift
    Hi I have a 2008 tacoma 4x4 with a 6" fabtech lift. One day i noticed when ever i turned my steering wheel it made a loud squeal whether i was parked or moving. I replaced my ripped tie rod ends and installed a new rack and pinion because it was leaking but still i get that same noise. If anyone could help this has been a long and frustrating problem.
    Thanks
  2. Oct 6, 2012 at 9:06 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Power steering pump, or the serpentine belt.
    Aged belt will slip under load and squeal, or if the pump is on it's last legs, it might be getting "tight" and causing the belt to slip.
    Replace the belt first since it's cheaper than the pump ;)
  3. Oct 8, 2012 at 12:25 AM
    rktacoma
    08 tacoma 6" lift
    ok thanks! I will try that...Hope it works cuz it sounds like something is binding too... It's hard to explain but its like if you had two moving parts and there was not enough lubrication...
  4. Oct 8, 2012 at 8:13 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    My thoughts exactly. Rich is just the master of all knowledge and once again beat me to it.
  5. Oct 15, 2012 at 11:39 PM
    rktacoma
    08 tacoma 6" lift
    ok i changed the belt the other day and still got the same noise. Sounds like something is not lubricated enough. What type of sound will a bad lower ball joint make? I just figured there aren't any more pivot points left.
  6. Oct 15, 2012 at 11:47 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    Did you check the power steering pump?
  7. Oct 16, 2012 at 7:16 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    fluid level is good? pumps go out..
    my wife's car is doing this. we are in a holding pattern waiting for it to go..just so you know, the demand on the pump is at it's greatest at the extreme end of your steering range.
  8. Oct 17, 2012 at 9:01 PM
    rktacoma
    08 tacoma 6" lift
    thanks for all the help everyone! gonna try and replace the steering pump soon...hope it works!!
  9. Oct 17, 2012 at 9:02 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Check your PS Fluid level first.
  10. Oct 18, 2012 at 7:48 PM
    rktacoma
    08 tacoma 6" lift
    the level was full
  11. Oct 19, 2012 at 12:09 PM
    aficianado
    back to bone stock.
    Then check belt. At full lock the pulley gets difficult to spin. So the belt slips then.
  12. Oct 20, 2012 at 8:53 AM
    rktacoma
    08 tacoma 6" lift
    Thanks for da help. I figured out the problem... The uni-ball on my total chaos UCA's just need some lubrication.. Now the sound is gone.. Thanks again everyone! Glad I didn't have to change the pump!
