squealing
Discussion in '1st Gen. Tacomas (1995-2004)' started by dennisc, Feb 2, 2014.
  1. Feb 2, 2014 at 7:24 PM
    dennisc
    dennisc [OP] Well-Known Member
    a few
    So I took the truck out a week ago for some off-roading and now I have a squeal coming from my right side...only when I'm driving. Thoughts?
    -2002 Toyota Tacoma 3.4L V-6 4x4
  2. Feb 2, 2014 at 8:16 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I think I need more info... How does it drive ? Any unusual pulling to left or right ? Maybe carrier? maybe crap stuck in caliper ? ..:notsure:
  3. Feb 2, 2014 at 8:47 PM
    tristen247
    tristen247 Member
    tristen
    colorado
    97' Tacoma SR5 V6 4x4 Manual 5-spd
    Cold air intake system and turbo charger
    I have the same squealing in my truck coming from the dash, it's a common problem in tacomas. I heard you can to a mechanic and have the gears in your dashboard oiled up.
  4. Feb 13, 2014 at 8:19 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    From engine? Check ac bearing. They like to fail.
    Check inside rotor dust shield for rocks.
    Gears under dash? Do elaborate!
  5. Feb 14, 2014 at 12:53 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Probably a rock in your brakes dust shield. Happens every single time I offroad...without fail. Super annoying.
  6. Feb 14, 2014 at 4:25 AM
    SPOTSONTROUT
    SPOTSONTROUT Well-Known Member
    ROB
    SOUTHERN ONTARIO CANADA
    03 TRD Stolen
    OME 882,DAKAR LEAF PAC WITH ADDA LEAF,285 TOYO OPEN COUNTRY MT,RACELINE RENAGADES,DECK PLATE MOD, MANUAL HUB CONVERSION
    Do you have manual hubs? Had to do mine last week . It was a crazy squeak only when I turned left on the right wheel . Good luck bud
  7. Apr 12, 2014 at 9:52 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Your an idiot. And you know why.
  8. Apr 12, 2014 at 10:16 PM
    ffirg
    mike
    Anchorage, Alaska
    Care to elaborate rather than attack people without explanation as to why? I wasn't aware getting mud/rocks stuck in my brakes while off-roading makes me an idiot. Other than not using my truck as a truck, I'm not sure it can be avoided :notsure:
    And by the way, I think you meant you're ;)
  9. Apr 12, 2014 at 11:15 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    You decided to leave me bad/neutral rep stating I provided useless advice; When you provided the same. Herpa derp much?
    As for grammer, the world will continue spinning. Hopefully.
    That's all. Kisses!
  10. Apr 12, 2014 at 11:59 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Why you crying? Pretty sure what was stated was true in regards to the squealing and why you got neutral.
  11. Apr 13, 2014 at 12:27 AM
    ffirg
    mike
    Anchorage, Alaska
    Definitely a derp moment. That was meant for the lovely comment before yours. I apologize.
  12. Apr 13, 2014 at 2:18 AM
    trded
    trded Active Member
    CA
    02 PreRunner TRD 2WD
    TRD Catback TRD Headers TRD SuperCharger TRD 7th Injector & ECU
    What a troll. Anyway always start with the easy stuff. I would check your belts and bearings before going wild and taking things apart. Remember sounds can resonate and may appear to be coming from the right side.
  13. Apr 13, 2014 at 5:40 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Probably a rock stuck in the brakes.
    Stop. Drive the truck in REVERSE and hit the brakes a few times. This should help dislodge and/or remove the rock/debris.
  14. Apr 13, 2014 at 5:40 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Well then I love you. I apologize. Lots of homo.
    Op, did you ever figure it out?
