SQUEEEEAAAKK!--> Attention Veteran Tacoma Owners!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tnjyoung, Jul 9, 2017.
  1. Jul 9, 2017 at 8:49 PM
    #41
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
  2. Jul 9, 2017 at 9:21 PM
    #42
    Danilo Ulises
    Danilo Ulises Member
    Danilo
    2013 sr5 tacoma
    It has the tacoma ready lift kit front and back, with some 285/70/17 falken tires.
    I have a 2013 sr5 with tacoma ready lift kit front and back, just so i could fit 285's and I have annoying squeek i dont know where is coming from, but i guess those leaf springs are the culprit.
  3. Jul 10, 2017 at 12:03 AM
    #43
    Ez2Tan
    Ez2Tan Well-Known Member
    2017 Quicksand Tacoma OR
    This morning I went through a mcdonalds drive through and the worker complimented on how nice my truck was and started some small talk about it. I was so embarrassed when I left because the truck squeaked so bad leaving the window. The truck sounds like its been a work horse daily for years.
  4. Jul 10, 2017 at 6:54 AM
    #44
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Mine doesn't squeak, not "normal" though I suppose it is common. Get under there with a high-pressure hose from a car wash and see if you can get any dirt from between the leafs. I also personally think spraying crap all over them does more harm than good from what I've seen. Only times I've heard squeaking is if I put silicone or fluid film on them. If it's just dirt, they don't squeak...
    Nice looking ride though - and if I'm not mistaken that almost looks like the Publix off the Ooltewah exit north of Chatt? :)
  5. Jul 10, 2017 at 7:09 AM
    #45
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Added a 3leaf AAL. When I did I cleaned out all the Leafs and added energy suspension grease between them. It's a very thick and tacky grease. More like a glue than a grease. So far no squeaks but it's only been a few months.
    Braves95 and GPsevinSixx like this.
  6. Jul 10, 2017 at 7:13 AM
    #46
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I have had pretty good luck fixing squeaks using some stuff called ATP AT-205. I had to order it via Amazon. This is suppose to stop leaks in transmissions, power-steering systems, etc. It basically rejuvenates the rubber seals. I use it in a different way. I dump it in a dedicated spray bottle and hit all the rubber bushings when I start to hear a squeak. I use it full strength. Within a day or so the squeak goes away for maybe a year+. I've been doing this on my '97 4Runner and now on the front bushings of my Tacoma. Works great.
    I also think you need to look at the bushings on the rear shocks. My truck was T-boned in a wreak 2 years ago and I guess the shock was damaged but didn't show up until a year later. Of course the insurance company said it was normal wear. The truck was squeaking back there but I thought it was leafs and was waiting for the TSB at the dealer. Before the leafs were replaced I replaced the rear shocks and the squeak went away. Must have been the shock bushings. I would hit the rear bushings with that ATP AT-205 stuff.
    Riding Dirty likes this.
  7. Jul 10, 2017 at 8:39 AM
    #47
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Same here... over 11k mileage on the same stuff without issue.
  8. Jul 10, 2017 at 8:43 AM
    #48
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    Pinche_tacos likes this.
  9. Jul 10, 2017 at 9:36 AM
    #49
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Have you like NEVER owned a truck before or something?? It absolutely is normal, WTF do think is going to happen when you stuff mud and grime between long pieces of metal that are supposed to flex and rub together?? How in the world are you supposed to design a squeak free leaf pack impervious to mud smartguy??
    ooohhhh but there's a TSB so it must be someone's else's fault!!! Except there's a TSB for this on literally every other offroad truck as well truck:
    Silverado/Canyon/Colorado/H3/Sierra TSB:
    https://www.carmd.com/Tsb/Download/96828/e3cea094
    Ford F-series TSB:
    https://www.f150forum.com/f38/creaking-noises-54962/
    Nissan Frontier TSB:
    http://tunfs.yuku.com/topic/1367/TSB-for-Squeaky-Leaf-Springs-NTB05117#.WWOqe69lCUk
    Ford Ranger TSB:
    https://www.truedelta.com/Ford-Ranger-tsbs-93,2004
    Trust me I'll find one for any truck built in the last 20 years....
    Just google ANY Truck model plus "rear leaf spring noise" and you'll get hundreds of threads on it. "titan leaf spring noise" "ranger leaf spring noise" "raptor leaf spring noise" "Silverado squeaky leaf springs" etc etc etc
    And you know whats weird?? All those different models and forums and its only Tacoma owners bitching about how it should be covered by Toyota, I seriously couldn't find Ford/Nissan/Chevy or even Tundra owners with the same attitude and if they did the replies were "dude its normal here's how to fix it". All the other owner forums and people just figure out a solution (which is pressure wash the leaf packs good and grease them up. Problem solved), but on tacomaworld you see a lot of people going in circles with ideas like "bitch to the dealer loud enough and make them fix it! you shouldn't have to!" or recommendations to "blast them on yelp" and just a general attitude that they're a victim of Toyota's apathy or something :jerkoff:
    If you offroad you're going to need to take care of your gear if you want it operating like new. Part of that is taking extra care to seal electronics if you do water crossings, it means cleaning your under carriage with saltaway if you dip it in the ocean, it means regularly waxing your paint to keep it protected, and it means PRESSURE WASHING AND GREASING YOUR FUCKING LEAF SPRINGS IF YOU GET MUD IN THEM.
    Sorry don't mean to be rude this place just bitches about problems instead of solving them too much sometimes.
    su.b.rat, JdevTac, Braves95 and 6 others like this.
  10. Jul 10, 2017 at 9:37 AM
    #50
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    Refer to my signature.
  11. Jul 10, 2017 at 9:52 AM
    #51
    jnw32
    jnw32 Well-Known Member
    Dallas, TX
    2016 White Tacoma TRD Off-Road DCSB
    265/75/16 KO2s, SR5 Grille, TRD Pro skid plate, Husky X-Act Contour floor mats, Carhartt front seat covers, de-stickered, partially de-badged, Bilstein 5100s with one inch rear block
    The dealer replaced my leaf springs under warranty because they were squeaking, and the dealer did it on their own initiative too, believe it or not. I haven't been off-road since, so I don't know if the squeak will return or not. Probably will, but for now it's nice - nice and quiet!
  12. Jul 10, 2017 at 11:32 AM
    #52
    verdegreene14
    verdegreene14 Active Member
    Brian
    Central, AZ
    08 Black Taco Turd
    Buy plastic spacers in bulk somewhere. Only thing that stopped the squeak in mine. Jack up the back so the leafs separate a bit, replace the stupid plastic pad, then you should be good for a few more mud holes. Good luck.
  13. Jul 10, 2017 at 1:29 PM
    #53
    RPV3013
    RPV3013 New Member
    Red Tacoma
    Next time wash it!
  14. Jul 10, 2017 at 2:17 PM
    #54
    Taconator87
    Taconator87 Well-Known Member
    My undercarriage was covered in dirt from mudding a little bit. It starts squeaking so I sprayed it down and the squeak stopped.
  15. Jul 10, 2017 at 2:43 PM
    #55
    Pinche_tacos
    Pinche_tacos Member
    Doug
    2016 trd offroad double cab.
    White lightning!!!!
  16. Jul 10, 2017 at 3:52 PM
    #56
    Jaque8
    2017 Inferno TRD OR
    This will vary from dealer to dealer even service advisor to advisor so although you got lucky I wouldn't count on this being a warranty covered issue.
    They fixed it on my 2nd gen for free too but it was mostly because of a recall that gave me new leaf springs anyways, even after the new leafs it only took a couple offroad trips and the squeak was back, then I just kept power washing and greasing power washing and greasing a constant battle to keep them silent. Eventually I put nylon insulators between the leafs and that seemed to be a more permanent solution, at least it didn't require a good greasing every few offroad trips but still needed a good power wash every now and then.
    On my 1st gen I never even bothered fixing it because it was already a squeaky old truck. On my new 3rd gen I've basically soaked my leafs in white lithium grease after I power washed and cleaned them by hand. Its been on 5 offroad trips since then and still no squeak but I anticipate I'll eventually have to put in some nylon like on my second gen.
  17. Jul 10, 2017 at 3:55 PM
    #57
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Easy fix. 3 link rear with panhard and coilovers.
    stvstoy and CLOUDL1GHT like this.
  18. Jul 10, 2017 at 4:05 PM
    #58
    jnw32
    Dallas, TX
    Yes, I agree, a couple of dealers, including the one that fixed it, had looked at the squeak and just power-washed it as a fix. Which would work for a little while, and then the squeak would come back. I had just gotten used to it. Then, when I took my Taco in for its 20,000 mile service the service manager came out and said they noticed the squeak and that they would take a look at it. At first I said not to worry about it (as I figured I would just get another power washing), but he said they might replace the springs under warranty, so I said ok. They looked at it and decided to change the springs out. I'm not holding out too much hope that they won't squeak too though once I go off-road. Unless they somehow changed the design of the springs, I think the new ones will have the same problems as the old ones.
  19. Jul 10, 2017 at 8:26 PM
    #59
    thecoloRADoinferno
    thecoloRADoinferno Well-Known Member
    2017 Tacoma Inferno TRDOR DCSB
    My '17 Taco TRDOR had the same squeak after a little mudding session...so I power washed the leafs and surrounding suspension areas, let it dry, took some Fluid Film and drenched the leafs. Then I rocked the truck side-to-side to let the film seap into the leaf packs. No squeak for about 2 months at this point...hopefully it lasts!
    Also, to anyone that says you should deal with a $40k truck, please go away. That is the most ridiculous thing I have ever heard. Leaf springs were one of, if not the earliest, form of suspension. Meaning lots of times to figure it out and engineer it further. These trucks shouldn't squeak. Sure, other trucks may also squeak, but we are talking about Toyota/manufacturing companies discovering a way to produce quiet leaf springs (not GM, Ford, Chevy)...
  20. Jul 10, 2017 at 9:04 PM
    #60
    UrbanT@co
    UrbanT@co Taco FANatic
    Craig
    Bay Area
    '16 DCSBOR 4x2
    * BAMF Grille *50% tint driver/passenger front window * NFAB steps * Bakflip F1 tonnaeu * Bed extender * Bed mat * Weathertech digital floor mats * Black reflective Tacoma tailgate decal
    Mine has a slight squeek now when I get out. Doesnt bother me given the tacoma history on this.
    My 1st gen had a notorious squeak that would not go away even after the leaf packs were removed and lubricated twice.
    Granted it's a $40K truck, it'll continue to depreciate and eventually the value of the truck will be inline with how it sounds.
    Best course of action may be to file a claim with Corporate.
