Squeek?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaman04, Aug 2, 2009.
  1. Aug 2, 2009 at 10:28 PM
    tacomaman04
    tacomaman04 [OP] Well-Known Member
    tx
    prerunner SR5
    volant CAI helix throttle body spacer Westin Black Bull Bar Kc Slimlites130watt long range Black out Taillight Mod Flat Black Rims Flat Black Emblems Two 10' Kenwoods 1200Watt Alpine Amp Surround Black grill Flat Black Front and Rear Bumper
    When I turn or drive slow my truck sqeeks. But when i press the brake it stops. Can it be the shocks or the brakes?
  2. Aug 2, 2009 at 10:33 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Could be dirt in your leaf springs....
    does it squeak when going over bumps?
  3. Aug 2, 2009 at 10:44 PM
    tacomaman04
    tx
    prerunner SR5
    Yes alot
  4. Aug 3, 2009 at 3:50 AM
    ChrisYoTaCoMa
    ChrisYoTaCoMa Chrome's for Harleys and old farts
    Estero, Floriduh
    00 Taco 4x4 Ex cab 2.7 sr5 AT
    New Pioneer stereo, and all 4 speakers with Infinity components. Sirius satellite radio. Deckplate mod done. Door buzzer silenced forever thank God, tinted windows, vent visors, hood protector(bug guard), ceramic pads and new rotors, dechromed EVERYTHING. 2" Lift front 3" rear. Skyjacker AAL's and replacement leafs(and front spacers) from Fatbobsgarage.com. Skyjacker 7000 Hydro rear shocks, those Bilstein 5100 fronts are coming soon!
    How do you stop that? Mine does it a little.
  5. Aug 3, 2009 at 3:54 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Go to the carwash and spray high pressure water/soap inbetween the leafs.
    Wait a couple days before determining if the squeeks are gone - the 'water' (wetness) will stop the squeeks immediately. It's after the water is dried - will you know for sure if the squeeks are gone.
    If you wash your leafs and the squeeks are still there - then it's something else causing the squeek.
  6. Aug 3, 2009 at 8:24 PM
    Lentsnh
    Yes go to a car wash with a pressure washer and put as much water as you can between the leafs..
    If the squeak is still there after you have done the washing... put some light grease between the leafs
  7. Aug 3, 2009 at 9:41 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Be sure to use lithium grease in your leafs. ;)
  8. Aug 3, 2009 at 10:07 PM
    Lentsnh
    White lithium grease
  9. Aug 4, 2009 at 3:53 AM
    ChrisYoTaCoMa
    Estero, Floriduh
    I think mine is the new AAL's. They didn't have rub pads at the ends. It's not bad at all. Yet.....
  10. Aug 4, 2009 at 7:34 AM
    Lentsnh
    Mine didnt either..... They only squeak when I am done going off road
  11. Aug 4, 2009 at 2:16 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    How are the brakes ? Are they good? With good pedal pressure on top? If they're getting down there (usually front brakes w/ disc ) Does it pull to the left or right noticably when you brake from say 35-40 mph ? & if it sqeeks when you turn I'll bet its a left hand turn isn't it ? It could be the anti rattle clips that also start to make contact with inner part of the rotor(non braking part) to let you know the pads are getting low before they (thin pads) actually make contact with rotor causing damage (that sickening sound & feel of grinding metal )
  12. Aug 4, 2009 at 8:02 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    maybe its the brake pad wear sensor... usually theres a little metal piece that makes contact with the rotors when its time to change the pads.
    check both front pads to see how much is left, but it sounds to me like you need new pads. its probably not suspension because you said it goes away when you step on the brake pedal.
  13. Aug 4, 2009 at 10:49 PM
    Lentsnh
    But he said(OP) that the squeak goes away when he presses the brakes...
  14. Aug 4, 2009 at 11:37 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Exactly, sqweek goes away when brake is applied, now I'm pretty sure it IS a thinning of the pads, because they've worn down enough to create a gap between the pad surface (inboard pad is against the piston coming out of the caliper) & the rotor, plus the pressure from braking temporarily will stop a sqweek, but my moneys on a brake job soon
  15. Aug 5, 2009 at 5:36 AM
    STLharry
    Harry
    VT
    agreed. the sound goes away when the brake is applied because the pads then come in contact with the rotors.
  16. Nov 19, 2009 at 5:20 AM
    TRD_yota_nc
    TRD_yota_nc hey big man lemme hold a dollar
    North Carolina
    08 4x4 TRD BLACK
    3 inch Toytec suspension lift, Cooper Discoverer STT, Moto Metal 951, UWS tool box, all weather mats, window tint, K&N Cold air intake, Airaid tbs, rubber tacoma bed mat, Wilson "Little Wil" cb antenna,
    What could it be if its not the leaf springs
