Squeeking Front Susp. after lift!
Discussion in 'Suspension' started by BEEFY_CHEESY_TACO, Nov 6, 2010.
  1. Nov 6, 2010 at 7:47 PM
    BEEFY_CHEESY_TACO
    BEEFY_CHEESY_TACO [OP] DUDE MAN BRO
    Hot Carl!!!
    Roy UT
    2010 TRD-Off Road TACO Extra value package
    Icon Ext Travel w/ Resi Front and rear, Dakar leaf springs, total chaos UCA's, color matched rear bumper, color matched satoshi grille with black chrome TRD emblem, konig countersteer offroads (black) w/ 285/75 Duratracs, sockmonkey Trailiens 3rd tail light cover, Tacomaworld.com sticker (made by me), debadged all around, Relentless Front Bumper, Sliders, Rear bumper, and bed bars with Yakima rack w/ full size spare, shovel, hi-lift
    So about 2 weeks ago I installed my toytec ultimate lift kit and total chaos UCA's. Before the suspension broke in and settled a little bit there wasn't any noise at all, probably cause the suspension was still stiff and not really moving much. Now after I've settled a bit I'm getting a lot of squeeking out of the front end. I've greased the UCA's twice (once during installation and again just a couple days ago) and tried spraying everything (shock mounts and anything else that was messed with during installation of the lift) with PB Blaster to try and lube it all up. It seemed to have made a difference for about 10 miles or so but came back.
    Is this something that once the components of the lift will eventually break in further and go away? Any ideas or suggestions are greatly appreciated. Thanks!
  2. Nov 6, 2010 at 7:55 PM
    Gabex35
    Gabex35 Well-Known Member
    Gabe
    San Diego
    2020 Tundra Limited 4x4 Crewmax
    Sub'd
  3. Nov 6, 2010 at 7:56 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Did you grease the UCA bushings?
  4. Nov 6, 2010 at 7:57 PM
    BEEFY_CHEESY_TACO
    Hot Carl!!!
    Roy UT
    theres two grease fittings on each UCA that i greased. Thats all
  5. Nov 6, 2010 at 8:01 PM
    S.B.
    Sean
    San Diego
    15 Taco
    And the uniball?
  6. Nov 6, 2010 at 8:05 PM
    BEEFY_CHEESY_TACO
    Hot Carl!!!
    Roy UT
    theres no grease fitting on the unibal. how would i grease it?
    If these questions sound dumb its because I'm more of a powertrain mechanic rather than suspension.
  7. Nov 6, 2010 at 8:07 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Oh theres your problem. Get some dry teflon spray (dupoint makes some available at lowes) and spray the uniballs top and botton.
  8. Nov 6, 2010 at 8:08 PM
    BEEFY_CHEESY_TACO
    Hot Carl!!!
    Roy UT
    cool ill try that first thing in the morning. I appreciate the help man.
  9. Nov 6, 2010 at 8:10 PM
    S.B.
    Sean
    San Diego
    15 Taco
    yep, no problem. All uniball UCAs need some lube on the uniballs so they don't squeak.
  10. Nov 6, 2010 at 8:13 PM
    BEEFY_CHEESY_TACO
    Hot Carl!!!
    Roy UT
    cool hopefully thats it cuz its driving me f-in nuts!
  11. Nov 6, 2010 at 8:15 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    x2. Also don't forget to hose them off really well to take off any dirt on them then spray them. I think you need to wait and let them dry before spraying but I'm not 100% sure.
  12. Nov 6, 2010 at 8:19 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Also the bushings need to be greased inside and out side when you install them. Its mentioned in the instructions
  13. Nov 6, 2010 at 8:21 PM
    BEEFY_CHEESY_TACO
    Hot Carl!!!
    Roy UT
    ok cool. i use dry lube all the time at work and didnt even think of it being the uniball.
  14. Nov 6, 2010 at 8:21 PM
    BEEFY_CHEESY_TACO
    Hot Carl!!!
    Roy UT
    i did the bushings just not the uniball
  15. Nov 6, 2010 at 8:26 PM
    ktmrider
    Junk
    Well Ive heard if you just do it from the zerk and you dont grease it when installing they squeak as well. 2 weeks ago when I did mine I did the uniball and inside and outside of bushing when installing them and I haven't had a single squeak.
  16. Nov 6, 2010 at 8:37 PM
    BEEFY_CHEESY_TACO
    Hot Carl!!!
    Roy UT
    cool. ill have to loosen my uca bolts and get in between the bushing and washer thats there and grease 'er up nicely.
  17. Nov 7, 2010 at 11:19 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Did it fix the squeaking?
  18. Nov 8, 2010 at 12:22 AM
    BEEFY_CHEESY_TACO
    Hot Carl!!!
    Roy UT
    actually tomorrow ill be getting into it. I have tomorrow off and don't have anything planned. I will keep ya posted!
  19. Nov 8, 2010 at 5:41 PM
    BEEFY_CHEESY_TACO
    Hot Carl!!!
    Roy UT
    ok so here what happened. Today we started on the drivers side UCA. Pulled it off and greased everything up real well, it was already greased pretty good but just wanted to make sure. The passenger side UCA was very very tight and once I saw it I immediately knew that was the problem. I had to hit it with my fist to move it up and down. I was able to find the torque specs for the UCA bolts and torqued them right this time. So I didn't even take apart the passenger side, I just loosened the bolt and torqued it to spec. SO FAR SO GOOD!! Goes to show how important torque specs are rather than the good ol american "good n tight". Thanks for all the help guys.
  20. Dec 9, 2010 at 8:58 PM
    roughnready62
    roughnready62 Well-Known Member
    Fairbanks, Alaska
    02 SR5
    K&N Intake SoftTopper
    I'm running into squeaking issues as well. what are the torque specs you found?
