Squeeking Steering Wheel
Discussion in '1st Gen. Tacomas (1995-2004)' started by dylandercole, Feb 2, 2010.
  1. Feb 2, 2010 at 8:32 AM
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    This only happens about 40% of the times im driving but when moving the steering wheel its making a squeeking/squeeling noise. It sounds like its coming from underneath where the pedals are. It also sounds more like a pump going bad than a bearing or something that needs lubrication. I couldnt pinpoint it so im looking to you folks. help me out please
  2. Feb 2, 2010 at 8:50 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Well, at least it is not your clutch...........:D
    Check the steering wheel shaft. There should be a bearing on it, but not sure if it can be lubed?????:confused:
  3. Feb 2, 2010 at 7:32 PM
    dylandercole
    Dylan
  4. Feb 3, 2010 at 10:21 PM
    angela
    angela Well-Known Member
    check the bearing on the steering shaft, lube it if you have access to it. also check the boot where the shaft exits the cab. a can of white grease works wonders
