Squeeks at start up then goes away. Bad belt?
Discussion in '4 Cylinder' started by bc8774, Aug 19, 2011.
  1. Aug 19, 2011 at 10:10 PM
    bc8774
    bc8774 [OP] New Member
    98 tacoma sr5
    My 98 tacoma 4cyl squeeks at start up then quickly goes away. Belt im guessing.
  2. Aug 28, 2011 at 1:19 PM
    Allen9621
    Allen9621 Active Member
    Northern California
    1996 4x4 5-speed
    Off the record, you may be able to get over 200k on the original factory belts without them cracking or wearing, depending on the climate where you live. Just spray on belt dressing when one starts to squeak, or correct the belt tightness over time.
    My alternator belt eventually caused a whining noise when idling with the lights on (more current draw). Tightening it up made that go away.
    The Toyota factory belts can be maintained for a surprisingly long time with belt dressing - vs. the hassle of replacing them. Just watch for any cracks and pitting on the working surfaces. "YMMV"
  3. Aug 28, 2011 at 1:25 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    spray it with armorall.
  4. Aug 30, 2011 at 12:47 PM
    98ToyWheeler
    98ToyWheeler Well-Known Member
    Tyler
    98 SR5 4x4
    JVC head unit, Polk audio Speakers (front), Pioneer (rear), FLI Trap Passive 12 Sub, Fixed Window strip,Tool box, Plasti Dipped Grille, emblems, bumpers, and fender pieces, python keyless entry and alarm
    Just took my truck to the dealer to get the AC fixed and mentioned this as well. They said that one of the belts was to tight and fixed it for me.
  5. Sep 1, 2011 at 10:37 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Truck stored outside? Maybe the "morning dew" got in there and with a little moisture a belt can squeak until dry..:confused:
  6. Oct 3, 2011 at 7:09 AM
    00PreRunner
    00PreRunner Well-Known Member
    New Albany, MS
    '02 TRD 4x4
    2002, auto to manual swap. 35's and 5.29's
    Try tightening your alternator belt.
