Squeeky Dakar Leafs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EastVanTaco, Jan 12, 2019.
  1. Jan 12, 2019 at 10:07 AM
    EastVanTaco
    EastVanTaco [OP] Well-Known Member
    2017 super white Trd Sport DCLB
    I had the heavy duty leaf pack installed. After 6 months they squeeked so bad it was unbearable and embarrassing. After many emails I had ARB parent company of OEM suggest i pay to have them greased with a special greese. I did and nothing changed. So they replaced them with what was supposed to be an upgraded leaf.
    Now after 1 year of driving the squeeks have come back. The leafs come with a 3 year warranty.
    I made several attempts to contact ARB via email. I do not seem to get a reply. I dont feel that coating them in an oil spray is a fix. Its a temporary solution.
    Thoughts?
    jowybyo likes this.
  2. Jan 12, 2019 at 10:24 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Thoughts? Well, all of my older Toyota trucks had the squeeks. It gave them character. My 2017 with a single Deaver AAL leaf added to stock has character only after I OR on dusty roads too, but the only issue I’ve had with that is it tends to ruin the mood when you’re in the RTT late at night.:D
    Donjuan and Jaque8 like this.
  3. Jan 12, 2019 at 10:54 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    When I put in my AAL I pulled the stock pack apart and greased them and the metal shims up with synthetic Red Line, so far, so good.
    I’ve read where the grease and other lubricants attracts more dirt, but not sure how there’s any other way to quiet the leafs down.
  4. Jan 12, 2019 at 11:17 AM
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    Get proper leafs. Mine squeaked from day 2 of install. A lot Of the squeaking is from the attachement points. As well.
    If you lube the springs use a dry lube. Not a wet one it’ll just attract more dirt.
  5. Jan 12, 2019 at 1:04 PM
    EastVanTaco
    Wtf u mean get proper leafs?
    The company should manufacture proper ones for the price.
    At this point i wish i had just added a add a leaf to factory leaf
  6. Jan 12, 2019 at 2:06 PM
    aaen
    Northern Alberta
    They are garbage leafs, can’t support the weighr aqueak wirse then stock.
    I did the same thing, and regret jt. Thankfully they are warrantying my springs as I bought them as I was assured they could and the squeaking was handled by their rep.
  7. Jan 12, 2019 at 2:30 PM
    EastVanTaco
    Had mine replaced with an updated set ayear ago. The squeek is back.
  8. Jan 12, 2019 at 2:34 PM
    Clearwater Bill
    Billy
    Largo Florida
    All leaf spring have squeaked since stage coach days.
    There are several good solutions available. Many posted in TW, many to be found via Google.
    There is no reason to 'live with it'. But it does take some investigation and effort to improve.
    DrFunker, Gunshot-6A, MY50cal and 2 others like this.
  9. Jan 12, 2019 at 2:38 PM
    Gfunk123
    Gfunk123 Well-Known Member
    '13 limited taco
    3” level kit front, Dakar HD w/ Billy B110’s, 1.25” spidertrax, 265/70r18 Falken Wildpeaks AT3W
    Don’t have an issue with mine well not yet. Why don’t you share if you are in the know on how to fix.
  10. Jan 12, 2019 at 3:06 PM
    aaen
    Northern Alberta
    Never had a squeakky leaf on ford/chevy ever. Every toyota yup.
  11. Jan 12, 2019 at 3:12 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    I did WD40 to push out moisture and did white lithium grease. That was a year and a half ago no issues. Light offloading though plenty of water dirt and mud since
  12. Jan 12, 2019 at 3:15 PM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    The springs are metal on metal and unfortunately without some type of lubricant squeaks are inevitable. Silicone paste type greases may last longer than oil based if applied with the leaf pack disassembled. The biggest advantage of a fluid film is being able to apply it without taking anything apart. Since the pack has no seal it will eventually loose its lubricant and need to be touched up.
    The bushings are also a source of noise. I used energy suspension grease on mine.
    synaps3 likes this.
  13. Jan 12, 2019 at 3:55 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I’m not sure what you want here. It’s just metal slats bolted together. Metal on metal rubs, it happens.
    I recommend tearing the pack apart and using an axle grease around the center pin and on the last few inches of the leaf ends.
    I did this on my Deavers and no issues. You can try using plastic spacers but it’s up to you.
    Never use WD-40 or sprays on the leafs.
    Gunshot-6A likes this.
  14. Jan 12, 2019 at 3:56 PM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    DrFunker and Gunshot-6A like this.
  15. Jan 12, 2019 at 8:59 PM
    Oscar I
    Oscar I No longer a toyota driver
    OME TSB001 has the fix for this. Should have been done on install.
    beergeek likes this.
  16. Jan 12, 2019 at 9:04 PM
    Oscar I
    Wow I just read the idiotic comments. Some of you would have been better off with a 4runner. Coils have the benefit of no maintenance
  17. Jan 12, 2019 at 9:08 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Helpful :thumbsup:
    JCOOR likes this.
  18. Jan 12, 2019 at 9:11 PM
    Oscar I
    Covered that one post prior champ. Even included the instructions.
    You're welcome
  19. Jan 23, 2019 at 7:36 AM
    ChrisSandstorm
    ChrisSandstorm Well-Known Member
    '01 Land Cruiser, '16 TRD OR DCSB
    I registered online with ARB warranty. I installed my Dakar HDs last summer. Pretty noisy and I have sprayed a lot of liquid wrench on them not knowing that was the wrong thing to do.
    Hopefully, I can get the TSB kit from ARB. Other than that these are fantastic Leafs IMO. I have a Snug top topper and often have a lot in the back, the Springs are really plush and have held their lift well.
  20. Jan 23, 2019 at 7:39 AM
    sfgiantsguy28
    sfgiantsguy28 Active Member
    2018 Tacoma TRD Pro
