Squeeky door hinge
Discussion in '1st Gen. Tacomas (1995-2004)' started by mn.cadena, Jun 18, 2008.
  1. Jun 18, 2008 at 6:51 AM
    mn.cadena
    mn.cadena [OP] Active Member
    Mississauga, Ontario
    01 PreRunner Xtra Cab SR5
    I have an 01 pre-runner stepside that I recently purchased. I love everything about it especially that it only had 42k miles and I got it for $12K. The only problem I seem to have is that my driver side door squeeks about half the time when it opens and closes. Is there any quick fix for this or do I have take it in to have the door adjusted?
  2. Jun 18, 2008 at 8:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I had the same problem on my 2000. Get some penetrating lube ( like PB Blaster) and give it a shot in the hinge. Mine was squeaking in a blind area, so I just shot some lube where I thought the squeak was comming from. It was the last time I heard from the squeak. :)
  3. Jun 18, 2008 at 8:05 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Or you can use some white lithium grease.
  4. Jun 18, 2008 at 8:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    White lithium grease is good, but cant penatrate into tight spots. It definatly would last longer than a penatrating lube. :)
