Squeeling belts at startup
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Feb 20, 2014.
  1. Feb 20, 2014 at 8:56 AM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    About time to replace my belts. Im looking this kit:
    http://www.amazon.com/Timing-Belt-T...bs_auto_4?ie=UTF8&refRID=1Y1J2RSTM2D4XHGGN2YY
    Its a bit $$$ and Im wondering if I can just replace the belts and be good. Do I need a the included "water pump, timing belt tensioner (hydraulic auto-tensioner, not a bearing), timing belt tensioner bearing, timing belt idler bearing, thermostat with gasket, front crankshaft seal, two camshaft seals"?
  2. Feb 20, 2014 at 8:58 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    just go to a parts store and get 3 new belts.
    Or..just tighten the belts a bit. Usually the PS or Alt one that squeals. PS tensioner is kinda a pain to get to. but if they look okay just tighten them
  3. Feb 20, 2014 at 9:06 AM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    If it's just a belt squeal why do you want to change the water pump and seals ect, just change the belts unless you have a lot of miles on the truck.
  4. Feb 20, 2014 at 11:29 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Probably should have put this in my origianl post. My belts were last done at 60k and its now at 125k. Toyota recomends replacement every 60k miles.
    I dont want to drain the fluid as its pretty much new. Im thinking just the belts and maybe timing belt?
  5. Feb 20, 2014 at 11:52 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    What he's saying is the squeal is being cause by one of the 3 belts, no need to replace the timing belt unless its giving you problems. You can just replace the 3 for like $40 or tighten them
  6. Feb 20, 2014 at 12:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ahhhh
    okay.
    If you ahven't done the timing belt your over due by 10k miles. Do the water pump while your at it.
    You can check the tension pulleys but if they are fine..no need to replace yet.
  7. Feb 20, 2014 at 12:04 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Thats what I figured, damn. How do I do the timing belt? I know the knotches have to be lined up perfect... Ill have to do some searching agian...
  8. Feb 20, 2014 at 12:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea you have to set the timing correctly. Not too bad..but time consuming. Im sure you can do it. If you can't...you shouldn't be turboing it :p haha
    Sorry i don't know of any write ups on it...ill admit i didn't do my tacoma as i didn't have the time too as it was my only vehicle. What a waste of money..700 bucks for timing belt, water pump and new fluids around. could saved a lot of money on it. But i did my supra and it wasn't too bad.
  9. Feb 20, 2014 at 12:30 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Haha, no shit! Thanks for the vote of confidence :eek:.
    Ill have to put in a week of vacation to knock this out, do the turbo install, and CV boot replacment.
  10. Feb 20, 2014 at 12:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    id just pull the motor for that then..make it easier for the exhaust side and timing actually..
  11. Feb 20, 2014 at 2:42 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Not a bad idea... Dont have a lift though...
  12. Feb 20, 2014 at 8:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bet get one...might need it down the road ;) :p haha
  13. Jul 15, 2014 at 1:25 PM
    bbk3e
    bbk3e Member
    Raleigh
    99 Tacoma
    mostly stock
    I just replaced the water pump ($80) and thermostat ($15). I had to take the (3) belts off and then re-install them to replace the pump. The squealing I had every time I turned on the AC is gone. Previous to that, I had to replace the alternator (and replaced all the belts at the same time).
    I currently have 199,466 miles on the odometer. ('99 tacoma 2wd 2.4L).
    The squealing is gone, but I'm not sure I had to replace the water pump.... Oh well, it was passed the time to do it anyway (I guess).
  14. Jul 15, 2014 at 1:43 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah, I think mine were squealing because the belts were loose. Tightened them up and g2g.
