Squeeling noise
Discussion in 'New Members' started by steve99tacoma, Dec 12, 2010.
  1. Dec 12, 2010 at 5:09 PM
    steve99tacoma
    steve99tacoma [OP] New Member
    Nevada City, CA
    99 6 cyl 4wd
    Replaced the radiator on my 99 tacoma 6 cly. Thought I should replace all belts. Have a horrible squeeling noise. I did take the power steering pulley off. Any suggestions.
  2. Dec 13, 2010 at 12:58 AM
    garetcurry
    garetcurry Well-Known Member
    Squealing is usually caused by a loose belt. Here's a cool test. With your truck running, turn your trucks wheels as far as you can to the left or right. After you've reached the limit, still try to keep turning the wheels in that same direction. If it squeaks louder or more pronounced, its probably your power steering belt.
