squeezing out more mpg when towing
Discussion in 'Towing' started by Dogfish, Oct 13, 2012.
  1. Oct 13, 2012 at 6:18 PM
    Dogfish
    Dogfish [OP] Well-Known Member
    NJ
    2012 Taco sport
    I know that that towing a small camper that taller than the truck its going to cause severe wind resistance, but I want to know. My fourth time towing the camper to a camp ground yesterday and so far this trip was the worse for my mpg. Lol of course the wind and hills in Pa don't help. :rolleyes: I can't really complain it about but I would like see if anybody found a way that squeeze more mpg out of theirs. Maybe by adding somekind of engine mod or cold air intake or something. :D
    Maybe you guys can give me a couple of tips to do it.
  2. Oct 13, 2012 at 7:07 PM
    exploringcarolina
    exploringcarolina Well-Known Member
    Bill
    North Carolina
    2003 Tacoma
    The way I get the better fuel economy is slowing down. Tested my 4 cylinder Tacoma towing a travel trailer in the NC foothills @ 55MPH and got 17MPG. At speeds from 60 to 65MPH on the interstate I get 15MPG. Next test will be on the interstates @ 55MPH with the travel trailer. Tow a 2000lb boat @ 65MPH and get 20MPG on the interstate. This Tacoma gets 29MPG @ 65MPH unloaded/not towing on the interstate.
  3. Oct 13, 2012 at 7:24 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Elko, NV
    '09 Offroad
    Lift Armor Badassery with a shit ton of pin stripes 18% Tint
    The best way to improve mpg when towing is slowing down. Maybe aerodynamics :confused: not sure on that
  4. Oct 14, 2012 at 6:59 AM
    Dogfish
    NJ
    2012 Taco sport
    I know that pulling my travel trailer is like pulling a big brick through the air. lol
  5. Oct 14, 2012 at 7:18 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    I'm calling BS
  6. Oct 14, 2012 at 6:14 PM
    exploringcarolina
    Bill
    North Carolina
    2003 Tacoma
  7. Oct 14, 2012 at 6:18 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I used to tow far more than that with my 94 Toy Pickup, R22RE motor and a five speed.
    30 mpg empty, down to 15 while towing.
    Howard
  8. Oct 14, 2012 at 6:35 PM
    exploringcarolina
    Bill
    North Carolina
    2003 Tacoma
    Had a 87 Pickup with the 22R. One "great" Truck. Used to tow a 1000lb pop-up with it plus camping gear, truck in Avatar. The additional wind resistance of the taller travel trailer reduces fuel economy of the 4 cylinder Tacoma. It surprised me how well my Tacoma does with the 2000lb boat compared to the reduced fuel economy with the taller TT. The TT combined with camping gear in the back of the truck is about 2000lbs total. Next economy test will be towing the TT @ 55MPH on the interstate. Hope to do better than 17MPG.
  9. Oct 15, 2012 at 4:05 AM
    Dogfish
    NJ
    2012 Taco sport
    Okay, okay did some testing on the way home yesterday and i found out some things.
    I will slow down to 55-65 (going down hill) mph from now on and coast down the hills to pick up some momentum for the climb back up from now on. I also put premium gas in to see what would happen. That also seemed to help some. Got a a lot better this trip on the way back.
    Thanks Guys for your help.
  10. Oct 15, 2012 at 4:11 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    If your mechanically inclined, Lightweight engine pullies will net you a bigger MPG increase then the Cold Air Intake would.
  11. Oct 15, 2012 at 4:31 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Speed is the killer the best mod is back roads at 50MPH.
  12. Oct 15, 2012 at 5:37 AM
    exploringcarolina
    Bill
    North Carolina
    2003 Tacoma
    Will test fuel economy with the TT @ 50MPH on back roads too. With the 4 cylinder & 5 speed manual, don't need to shift to 5th under 60MPH. No tach, but revs sound low under 60MPH in 4th. This 03 2WD Tacoma 2.4L pickup has 3.58 ratio differential gears as per the following site:
    http://www.new-cars.com/2003/toyota/toyota-tacoma-specs.html
  13. Oct 15, 2012 at 1:41 PM
    2004TacomaSR5
    2004TacomaSR5 Sentinel Prime
    Jon
    Montana
    2004 Tacoma DCSB & '79 Toyota Pickup 4WD
    This, I've squeezed 17 out of my 4 banger too, taking it easy is key. I've always wondered about guys in diesels that blast by me on the freeway doing 80 pulling 5th wheels or other large trailers, what kind of mileage do they get? Bet it's hardly any better than a tractor-trailer loaded down with rip rap haha.
  14. Oct 15, 2012 at 1:46 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Has anyone messed with short tube headers for towing? I know it'd give you better low end power but it might help save some MPG's when towing also. Not sure on the mileage part, I haven't seen any results.
  15. Oct 15, 2012 at 2:20 PM
    exploringcarolina
    Bill
    North Carolina
    2003 Tacoma
    Have a friend with a F-350 dual wheel diesel that pulls a 35' camper/5th wheel. Think he said about 9 or 10MPG, if I remember correctly. Don't remember the 5th wheel weight.
  16. Oct 15, 2012 at 5:25 PM
    turbo325ii
    turbo325ii Active Member
    Brett
    Provo
    06' Double Cab TRD off road
    none
    I towed a car hauler with a mini cooper s on it, and got 17mpg. I went 55-65 the whole time.
  17. Oct 16, 2012 at 4:05 AM
    Dogfish
    NJ
    2012 Taco sport
    I think that you and everyone else in this thread is right about speed. From now on I will stay under 60 mph. Except for going down hill where I would need momentum for the climb back up. Its just going to be a learning curve for me with the new camper. Not to mention the other drivers around me think I can stop on a dime here in NJ. Gotta love somebody suddenly pulling out in front of you.:mad:
    As for mod like exhaust and air intake. I would think that would help at least a little. Hmmm .....looks like a experiment is order. :D
  18. Oct 16, 2012 at 5:28 AM
    Pugga
    Massachusetts
    F-150 Mod
    Keep in mind cold air intakes can actually make you LOSE low end power and give you gains up top. If I were you, I'd just get a high quality filter and call it a day...
  19. Oct 16, 2012 at 11:06 AM
    exploringcarolina
    Bill
    North Carolina
    2003 Tacoma
    We are going on another camping trip with the TT to the SC coast, will check fuel economy @ 55MPH on the interstate.
    Also like maineah's idea! Will plan a camping trip taking back roads @ 50MPH.
    Thinking about buying a 4.6L Tundra for towing the TT too, but in the end, I need to slow down with the Tacoma, burn less fuel, and not be in such a hurry. That's the most economic way for me to go. :)
  20. Oct 16, 2012 at 4:34 PM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
