squel in reverse while braking
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kaden420, Aug 10, 2009.
  1. Aug 10, 2009 at 11:57 AM
    Kaden420
    Kaden420 [OP] Member
    Alright, I have had enough of this high pitched squel when I am backing up and braking at the same time. It is a god awful noise that I want fixed. I have taken the brakes apart and cannot find the problem. Please if anyone has any suggestions, that would be great. I have a 04 toyota tacoma 4x4 DC. The only other problem that I have is the clunk that I get when i come to a stop. For that I am going to take apart and regrease it. Alright please have some ideas. I forgot to mention that I am stationed in Italy, so parts are limited. Thanks everyone.
  2. Aug 10, 2009 at 12:04 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Dose it ever make the noise when your off of the brakes and backing up or only when your on the brakes and backing up?
  3. Aug 10, 2009 at 12:10 PM
    Kaden420
    only when hitting the brakes
  4. Aug 10, 2009 at 12:27 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    I can't say I know what is causing the squel, but have you gone under your truck and checked some of the drive components like the drive shaft, rear diff.? You may wanna try finding the zerk fittings and lube up your drive shaft. Check the torque of the bolts on your drive shaft to the rear diff., change your rear diff. oil and check the gears, rebuild your rear brakes, trans. oil change.
    That may help out but also look and see if anything is out of the ordinary. Maybe someone else can chime in that knows more than me. Or just take it in and see what they can find.
  5. Aug 10, 2009 at 12:33 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Sometimes it's just a bunch of dust built up. Clean all the brakes really good. Hope that's all it is.:)
  6. Aug 10, 2009 at 12:35 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    would you say its coming from the front or rear?
  7. Aug 11, 2009 at 2:19 AM
    Kaden420
    it is definatily coming from the rear brakes. it also does it when i back up and pull the emergency brake. So i know it has something to do with the brakes.
  8. Jan 3, 2017 at 8:41 AM
    Crash721
    Crash721 Well-Known Member
    Brandon
    2013 Tacoma PreRunner
    285/70/17 BFG KO2's 4" Maxtrac spindle lift kit. Caliraised 30" slim led bar
    Im having the same problem on my 13'. Its def the brakes on mine, ive even replaced the rotors. On my truck its mostly coming from the front passenger side. Has anyone found a solution to this issue? Im almost to the point where im going to tear off the squealer to see if that helps. SOOOOOOOO Damn annoying!!!
  9. Jan 3, 2017 at 6:03 PM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    Take the rear hubs of and spray them down with brake cleaner along with the shoes and hardware. Then take a pic of them and post it. Maybe the pads are bad, or a spring might not be correct.
  10. Jan 3, 2017 at 10:08 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    So, you've have removed the drums to look at the shoes, springs, etc?
    What side is the noise coming from?
  11. Jan 4, 2017 at 8:37 AM
    Crash721
    Brandon
    On my post it was supposed say "its def the front breaks" I also stated its the front passenger side so ive done nothing with the drums. I know none of you can tell me what it is without looking at it but ive heard that toyota's are notorious for having brake issues. New Rotors - Really good shape pads not sure of the shape or quality of the springs
  12. Jan 4, 2017 at 8:48 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    1. Make sure the dust shield isn't rubbing on the rotor.
    2. Make sure there's no debris (like a pebble) trapped between the dust shield and rotor.
    3. Make sure the pad squealer isn't contacting anything.
    4. Make sure the anti-rattle clip isn't loose and it doesn't rub on the inside of the wheel.
    5. Make sure pad friction surface doesn't have debris embedded in it.
    6. Make sure the following are cleaned and well lubricated with brake grease or anti-seize:
    • The back of the pads
    • The back of the pad shims
    • Between the pad and the pad shims
    • The edges of the pad backing plates (that contact the caliper)
    • The pad retaining pins
    tan4x4 likes this.
  13. Jan 4, 2017 at 8:57 AM
    tan4x4
    Rick
    Folsom, CA
    On that earlier post, you also say " . . . it also does it when i back up and pull the emergency brake . . ."
    The e-brake only activates the rear brakes. :notsure:
    So the noise is coming from BOTH front and rear?
    If its the front, then check for a brake pad that is worn down enough so that the 'wear indicator' is now coming into contact with the rotor. That will make an awful squealing noise.
    EDIT: Shit, I just realized I was quoting the thread crasher (Crash721).
  14. Jan 4, 2017 at 9:05 AM
    KenLyns
    Belly of the Beast
    ^Yep, and he's got a 2nd gen, which has a different anti-rattle clip design.
  15. Jan 4, 2017 at 11:55 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    2003 Tacoma Extra Cab 2WD A/T
    I'm pretty sure you have brake pads that are lightly glazed. Think of pottery when it gets very hot, you can get a light glazing on brake pads. I just remove the brake pads. Lay some sandpaper out flat. Run the brake pads over the sandpaper in a cross hatch pattern lightly. ( Wear a mask.
    The rear drums...Take a strip of sandpaper and wrap it around the drum. (as if you were polishing a shoe) Concentrate at the shoe's edge's to get ride of the sharp angle to get rid of squealing.
  16. Jan 25, 2017 at 2:18 PM
    Crash721
    Brandon
    Sorry to just get back to yall. I originally thought it was glazing too cruisedon66 thats one reason why I replaced the rotors and when I replaced them I did make sure to sand the pads to remove any glazing that might have been on them. The only reason I didnt replace them also was because they literally had less than 5000 miles on them.
    Kenlyns if it were any of the things you stated wouldn't it do it in drive as well? It just baffles me because it only does it in reverse. Ill try and go over everything once more this weekend and get back with yall.
