Squirrels!
Discussion in 'Off-Topic Discussion' started by Hotdog, Nov 24, 2008.
  1. Nov 25, 2008 at 7:17 AM
    Hotdog
    Hotdog [OP] My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    neither can I!
  2. Nov 25, 2008 at 7:27 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    I will Pimp out my cats if want. You can keep them when the hit is done. :D
  3. Nov 25, 2008 at 7:49 AM
    taconinja
    taconinja Well-Known Member
    Pittsburgh
    08 Base 4X4
  4. Nov 25, 2008 at 7:49 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Not mine. The ones I released were just well fed normal grey squirrels... Harrisville was the closest I moved any of them to Connecticut :D
  5. Nov 25, 2008 at 9:16 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Yes, unless the opening is there for roof / attic ventilation, this is the way to go... ...and even if it is there for venting which as you described does not sould like is the case, louvered and screened venting can be added (cheaply) after installing a proper fascia board.
    Don't use the expanding foam for that. I am a Home inspector, and that would be a 'use' that while providing comic relief on my website, should not even be considered for that application.
    Also, insulation stuffed in there would not stop any critters from entering and might direct water inward as well as trap moisture against the wood, resulting in decay over time.
  6. Nov 25, 2008 at 9:21 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    what's your website?
    The gap is there for ventilation. I'm not sure what is necessary, but I plan on keeping it the way it is. I might go back with a stiff wire mesh around the outside and nail it on there.
  7. Nov 25, 2008 at 9:52 AM
    WNYTACOMA
    Clarence, New York
    My website for my home inspection business. I am self employed and have been doing it for since 2001...
    Good thinking. If it is there for venting, get some stiff fencing material (like the galvanized stuff around gardens) and either staple it (good staple gun or hammered staples) Maybe if you trimmed it with wood stripping (exterior grade) on the exterior, it would look a lot better, just stager the strips for appearance sake.
    You also might look go to H-depot or the like and see what kind of 'continuous' louvered venting they have. The louvered venting is typically inexpensive (though sounds like you need quite a bit of it) and screened on the 'inside' to keep insects out as well as the bigger pests.
  8. Nov 25, 2008 at 10:58 AM
    DevilsChild
    DevilsChild Well-Known Member
    Kenny
    In your head
    Yeah, what he said is fool proof and humane. Home Depot sells traps.
  9. Nov 25, 2008 at 1:01 PM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Get a bunch of cats and throw them up there
  10. Nov 25, 2008 at 1:03 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Or wait until nd's good and hungry and throw him up there. Being from SC I'm sure he's got at least 3 recipes for your unwelcome guests. :hungry:
  11. Nov 25, 2008 at 4:45 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Throw some old hotdog water in the attic. Squirrels really hate that stuff, especially when it's a few days old. You've gotta be careful not to get the insulation wet though or your house will smell like rotten ass on a hot summer day.
    You have to be careful about squirrel retaliation. They might call in these guys:
  12. Nov 25, 2008 at 4:50 PM
    mjp2
    NJ
    "Ha Ha! I'm in yer attic warming my yarbles!"
  13. Nov 25, 2008 at 5:04 PM
    majorvices
    majorvices Active Member
    Huntsville, AL
    08 PreRunner
  14. Nov 25, 2008 at 5:13 PM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    Just marvelous. I fell on the floor laughing.
  15. Nov 27, 2008 at 7:42 AM
    #35
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Well I guess you need to learn to like the patter of their little feet. If the problem isn't fixed getting rid of the few you have now won't solve it.
  16. Nov 27, 2008 at 7:56 AM
    #36
    Hotdog
    Hotdog
    Wet Okole Underwear
    I'm going to leave one alive to tell the story of their fallen brethren.
    I've got the exterminator coming on Tuesday. That should take care of the ones in there. Then I'll work on getting some welded wire mesh installed in front of the opening. Did I mention it is about 150' of opening?
  17. Nov 27, 2008 at 8:54 AM
    #37
    Roland
    Rhode Island
  18. Nov 27, 2008 at 4:00 PM
    #38
    Hot Tamale
    Hot Tamale Well-Known Member
    Pat
    Henderson, NV
    2012 Access Cab 4x2
    Earlier this year I heard noises up in my attic and thought it was squirrels. I had always heard that if you spread moth balls around in the attic that will get rid of them. So, I went up there and threw a box full around. As I was finishing up I was shining the flashlight around and lo and behold found what was making the noises.....bats! It's illegal to kill bats (something about because they eat so many insects) so I had to get an exterminator. He told me I shouldn't have put moth balls up there because the smell mixed with heat can have a toxic effect on humans and really does nothing for the squirrels. Anyway, the bats were getting in at the 4 attic vents at each corner of the house. The exterminator used a box that made a loud clicking noise to scare the bats out and then put wire mesh over the vents. I hate varmints!
  19. Dec 4, 2008 at 5:19 PM
    #39
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Well, they're back this year. Heard some noise in the crawl space behind my bedroom closet. Set up my have-a-heart trap and got this little guy. It's a flying squirrel. I brought it over to Rolands state. Left him off in Arcadia State Park in Exeter. About 10 miles from my house. I don't think he'll be back.
    Now I have to go up in the attic and see where he got in. Should be fun, all I have is a small access door inside a closet. Need a ladder.
  20. Dec 4, 2008 at 5:54 PM
    #40
    kmrofka
    kmrofka Im so hungry i can ride a horse...
    Arizona
    03 V6 Prerunner SR5
    Stripped down to the frame
    gasoline and a match....
