Squishy Brake Pedal - Fixed!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brandob9, Nov 18, 2009.
  1. May 5, 2016 at 11:56 AM
    Ano'ai808
    Ano'ai808 HoloHolo Kalaka
    Ano'ai
    Kahului
    2019 TRD sport
    2.5 fox 3-4in front/rear Dirt king fab LCA/UCA Locked rear bumps OME leaf pack ARB air 15%-5%tints
    You think that the rest is the problem? I always thought that the rear will work after you put so much on the break
  2. May 5, 2016 at 11:57 AM
    Ano'ai808
    Ano'ai
    Kahului
    2019 TRD sport
    Like first it's your front that will grab them your rear
  3. May 6, 2016 at 12:40 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    They all work together. The front just takes more of the force due to its location and the weight shifting forward.
  4. May 6, 2016 at 12:48 AM
    Ano'ai808
    Ano'ai
    Kahului
    2019 TRD sport
    Thanks!
  5. Jul 25, 2017 at 11:21 AM
    awolo
    awolo Active Member
    Aaron
    Medina, OH
    05' DCSB TRD Sport SR5
    Did this fix your problem? What you describes in your previous post is spot on to what im dealing with.
  6. Jul 25, 2017 at 11:33 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
  7. Jul 25, 2017 at 11:34 AM
    awolo
    awolo Active Member
    Aaron
    Medina, OH
    taco2010trd[QUOTED] likes this.
  8. Jul 25, 2017 at 11:37 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    You have to adjust star thing where drum just goes on then go where you can back up and hit the brakes a few times. The adjusters will tighten up where they need to be and have no mushy pedal........
  9. Jul 25, 2017 at 12:05 PM
    Ano'ai808
    Ano'ai
    Kahului
    2019 TRD sport
    Mmmm yeah I just did my drum breaks as well along with the spring kit
  10. Jul 25, 2017 at 12:30 PM
    awolo
    awolo Active Member
    Aaron
    Medina, OH
    Im glad to hear this brought back your pedal pressure and travel. Mine has me worried about quick stops.
  11. Jul 25, 2017 at 1:37 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  12. Jul 25, 2017 at 6:52 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I did remove the rubber plug but for the life of me I cant find any star adjuster in there at all.
  13. Jul 25, 2017 at 7:45 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The old US Cars the adjuster was at the bottom of the drum. These are more towards the top above the axle. You may have removed the inspection plug for looking at the shoes.
    Here is the plug:
  14. Jul 25, 2017 at 10:37 PM
    Syphrum
    Syphrum Well-Known Member
    Thousand Oaks
    2006 DCLB
    BFF Hybrid Front Bumper BFF High Clearance Rear Bumper - soon HomerTaco Grill BAMF Sliders CMC - soon Bilstein 6112/5160 Dakar Leaf Pack - medium Total Chaos UCAs OEM LCAs - thanks @gunny1005 ! Retrofit Smoked Projector Fronts/LED Rears - soon - thanks @LSC15 ! WeatherTech Floormats Sony Touch Receiver
    As mentioned earlier, application of the parking brake advances the adjuster. My old jeep was back up n stop. Manual adjustment of Rear brake shoe clearance should only have to be done during replacement of the drum.
  15. Jul 25, 2017 at 11:47 PM
    #35
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  16. Jul 26, 2017 at 6:14 AM
    #36
    awolo
    awolo Active Member
    Aaron
    Medina, OH
    My parking brake goes all the way down...and doesn't stop the truck from rolling one bit. Should I try "pumping" the parking brake?
    I tried the reverse 5mph, and hit the brakes thing, yesterday, there was no change in pedal pressure or travel. I tried it maybe 5-6 times. Even went to 10mph. Should this have been done with the parking brake, not the actual brakes?
    I think I may just pull the wheels and have a look see at this point. I also need to bleed the fluid. It looks very dirty/old.
    Truck has 201k on it. I may just pull the trigger and get pads/rotors/shoes and new adjustment screw assemblies, bleed with all new fluid and really overhaul the entire braking system. Its all only $125 from RockAuto.
  17. Jul 26, 2017 at 9:25 AM
    #37
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    There is a cable to adjust the parking brake under the shifter bezel, inside the cab.
  18. Jul 26, 2017 at 10:43 AM
    #38
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    If you don't get it close enough when putting drums on they won't be able to grab and adjust. Do what was mentioned up a bit removing the oval rubber plug on back of brake plate and move the star adjuster with a screwdriver til it won't turn (not with a bunch of pressure, just til it won't move any more clicks) then do the back up thing.
  19. Jul 26, 2017 at 10:50 AM
    #39
    awolo
    awolo Active Member
    Aaron
    Medina, OH
    My Truck is an Auto. So I have a Push Pedal.
  20. Jul 26, 2017 at 10:52 AM
    #40
    awolo
    awolo Active Member
    Aaron
    Medina, OH
    I will do this first thing then. I'm assuming I turn it right?
    Ran out to grab lunch and the pedal travel is just worrying me. I don't think the rears are even grabbing.
