Squishy Brake Pedal - Fixed!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brandob9, Nov 18, 2009.
  1. Jul 28, 2017 at 6:55 AM
    #61
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Probably some thin ass disintegrated paper thing stuck to the inside of the drum or on the end of the axle. I haven't had mine apart, 165k and still original set of shoes back there, lol. Hey, they haven't made noise or complained. Not sure I have ever seen any kind of gasket between drum and axle on any other car/truck I've had.
  2. Jul 28, 2017 at 11:11 AM
    #62
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Has it been cleaned regularly?
    The adjuster screw may just be dirty and frozen.
  3. Jul 29, 2017 at 4:37 PM
    #63
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    OP my want to figure on replacing the rear wheel brake cylinders, too. If they aren't leaking after replacing the brake shoes I'd be surprised. Doing it now will save you from having to replace both the cylinders and brake fluid contaminated shoes again.
  4. Jul 31, 2017 at 12:20 PM
    #64
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    I just did this drum adjustment after finding the thread. It worked. Here's my take:
    It should be noted that the metal adjustment tab needs to be pushed off the adjustment ring when backing it off (loosening the adjuster) otherwise the tab bends towards the hole and gets stuck. I used a second screwdriver to push it away from the ring.
    I tried the method of fully opening the adjuster until it wouldn't open any further, then backing it off 14 clicks. However, it doesn't actually "click" when backing it off since you have to push the tab off the ring... I just kinda eyeballed it and made 14 small movements. After doing this to both sides, I set the e brake a few times and then drove in reverse and applied the brake many times. No change at all and the pedal was spongy as ever.
    I took the rubber cap back off and clicked the adjusted only 5 times tighter on each side, then made sure the brakes weren't dragging. That did it! The brake system feels renewed and stops with much more authority now. I don't think the brakes have ever felt this strong, now that the rears are pulling their share along with the front brakes. After driving around for 30 minutes testing, I jacked up the rear and tested that nothing was dragging and noted that the rear drums weren't too hot.
    Below is an illustration showing how you need to push the tab off the ring when loosening it.
    Jimmyh likes this.
  5. Aug 3, 2017 at 1:29 PM
    #65
    electra_boogaloo
    electra_boogaloo Well-Known Member
    2007 Double Cab Long Bed
    okay, so i was trying this and had difficulty finding the star. broke out my cheap ass endoscope from Amazon and found it real quick.
    pic
    i tightened it until i felt resistance on the wheel and then used a pick to push back the spring plate and moved it back a few notches until i didn't feel resistance spinning. what a huge difference this makes! i feel like i actually have brakes now! i still don't feel like i have abs though.
  6. Aug 3, 2017 at 4:02 PM
    #66
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Brake shoes require periodic adjustment to ensure that they are positioned just above the interior of the drum for optimum bite, and the drums themselves should be checked for warping and thickness. Finally, check to see if your brake shoes show any grooves that could mean it’s time for machining or replacement: you want as much shoe surface area as possible contacting the drum when you push down on the brake pedal.
  7. Aug 3, 2017 at 9:11 PM
    #67
    Jimmyh
    SC
    2012 Prerunner SR5
    Do this to adjust the rear brake shoe clearance:
    From the Shop Manual: http://www.customtacos.com/tech.old.../06toyrm/06toypdf/06rmsrc/rm2006ta/042010.pdf
    ADJUST REAR DRUM BRAKE SHOE CLEARANCE
    (a) Provisionally install the hub nuts.
    (b) Remove the hole plug, and turn the adjuster to expand the shoe until the drum locks.
    (c) Using a screwdriver, release the adjuster 15 notches.
    (d) Install the hole plug.
  8. Sep 25, 2018 at 3:08 AM
    #68
    Bwthomas77
    Bwthomas77 Well-Known Member
    North Carolina
    12 dbl cab trd sport 6spd
    Supercharger, flowmaster exhaust, 4runner disc brakes, Volant CAI, ECGS bushing
    After replacing the shoes, springs/hardware, and cylinders - had squishy brakes. Initially thought it was a bad brake bleed, but this was the problem. Initially had the shoes sort of tight putting on the drum after a couple of pulls of the e brake. But driving around brake pedal felt very loose. Added 5 clicks to each side, it was a little better, 5 more clicks did the trick, brake pedal back to nice and firm.
