Squishy brake pedal
Discussion in 'General Tacoma Talk' started by Yellok9, Mar 7, 2024.
  1. Mar 7, 2024 at 6:47 AM
    Yellok9
    Yellok9 [OP] New Member
    Keith
    Taco crew king bed
    Badge black out, wheel upgrade
    My 2003 Tacoma has a squishy brake pedal even after bleeding and changing the brake fluid. Any thought on the real problem?
  2. Mar 22, 2024 at 8:39 AM
    pp2small
    pp2small Well-Known Member
    Brian
    Socal
    2022 TRD Offroad
    maybe the pads are too worn? after putting new pads in my car i generally can feel a difference in pedal feel.
    worst case scenario you may need a new master cylinder
  3. Apr 2, 2024 at 10:01 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    bleed the brakes, look for any leaks, check the rear drum cylinders for leaks too, and then id start looking at the master.
  4. Apr 6, 2024 at 6:24 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    Bleeding the brake fluid is not quite the same as flushing the brake fluid.
    Start at the pax side rear and bleed / flush until you have a steady & clear stream of new fluid coming out. Do not let the master cylinder run empty. Then move to the driver side rear brake and repeat. Then move to the pax side front brake and repeat. Finally and lastly move to the driver side front brake. Pretty common sense, but not everyone knows you must bleed / flush from farthest brake to nearest. On a 2003, you may go through 2-3 bottles of brake fluid.
    You need to be using a vacuum pump and brake bleeder kit and any evidence of air bubbles coming out of the bleeder screw(s) is proof you have compressible air in your brake lines. Thus, a mushy brake pedal feel.
    It might take you 100+ pumps of the brake pedal at each wheel before you bleed / flush all the snot outta your brake lines. The brake fluid should not dribble out, it should pulse / squirt out when your lines are clean and clear. And again, you must keep your master cylinder full at all times.
    It helps to have a friend in the driver's seat while you do your thing outside.
    During this entire procedure, you need to be looking for leaks. Front calipers and rear drums need a close visual inspection.
    Last but not least, your brake lines - the rubberized end pieces - on a 2003 may be soft and completely elastic by now. Soft & worn out brake line ends are often a very common source of a soft pedal feel.
    2003 Toyota Tacoma Brake Lines from $12 | CarParts.com
    And, again, when you are doing this, be looking for leaks everywhere.
    If you do this correctly, and for typically less than $100, you should easily be able to make your brake pedal feel like a brick.
