SR shock upgrade to Sport worth it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco__Tim, May 14, 2021.
  1. May 20, 2021 at 3:39 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    Honolulu, Hawaii
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Test drive a trd sport before you go out and buy the shocks. In my opinion its not worth it
    shakerhood and davidstacoma like this.
  2. May 20, 2021 at 3:44 AM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
  3. May 20, 2021 at 3:56 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    If your looking for better road handling, then the sport shocks should be an improvement. If you are looking for more off road, I’d like to point out that many folks with off roads upgrade to something after market.
    BSFord and davidstacoma like this.
  4. May 20, 2021 at 5:01 AM
    Harmon
    Harmon Well-Known Member
    Jacksonville
    2020 Tacoma SR V6 4X4
    265/75/16 BFG KO2's Front ARB Air Locker
    Get the TRD OR OEM Toyota Bilstein's or the 4600's if you want a economical upgrade option.
    The OEM TRD Toyota Bilstein's are a bit more narrow than the Bilstein 4600 but it is basically the same shock.
    I have them on my SR and it made all the difference in the world.
  5. May 20, 2021 at 5:13 AM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    Some questions for you OP:
    Is this the most you will spend on this truck? Or will you eventually want to upgrade to an aftermarket suspension?
    If the answer to the first question is Yes, then either the Sport or OR suspension is an upgrade and I would do it.
    If the answer to the first question is no, then I would wait and save up the money to get a higher level suspension.
    as for differences in feel. Yes, the OR suspension is supple. But I like it. My truck is not a sports car and I actually like the softer feel of the suspension. It's not cadi soft, but it takes speed bumps so easily, like their not there.
  6. May 20, 2021 at 5:30 AM
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    OP, it really depends on what you are looking to accomplish. Softer ride? Better handling? The Sport suspension will be firmer, so it’ll handle better on the road. Less body roll and nose dive when braking, but you’ll feel more of the bumps in the road.
    If you’re looking for a softer ride, then the OR suspension would be a better alternative. It’ll soak up bumps better, but has a lot more body roll and nose dives when braking. I personally didn’t like the squishy ride of the OR and would’ve changed the suspension if I had kept it longer. But a lot of people on here like it. Personally, if I was going to go through the effort of swapping suspension, I’d be looking at aftermarket. It’s more money, but there are a lot of options and you can get something to suit your needs better.
    Lt. Dangle likes this.
  7. May 20, 2021 at 8:38 AM
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    Why would you want that? If you're gonna go through taking off all that suspension might as well buy better shocks
  8. May 20, 2021 at 6:12 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    1) replacing the shocks is EASY. The struts are a little more work, but not bad. Not sure why you think that is insurmountable.
    2) The factory shocks are Bilstein, so they’re not an unknown. They are actually pretty darn good at doing their job, unless you are rock crawling or overlanding. But you’re right, those folks are planning to replace the moment they bought the truck. Great chance for the rest of us to get a nice compromise on the cheap.
  9. May 20, 2021 at 6:29 PM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    Test drive a TRD Sport first before you take the time, money, and effort to do this. My family has an SR5, OR, and Sport in the family. I now drive the OR. My favorite by far for the street was the SR5 2wd access cab, fast and lighter than the other two that have 4x4.
    In terms of the Sport vs the SR5 shocks/struts, the feel very similar. This is why I suggest, like others here, to test drive before you do anything.
  10. May 20, 2021 at 9:57 PM
    LilTexan22
    2017 Tacoma
    Easier said than done, I did all the suspension work on my truck and that shit takes a good couple hours. Why waste that time with more oem suspension when you have an opportunity for better aftermarket shit
  11. May 20, 2021 at 10:03 PM
    Ainapo
    Ainapo Well-Known Member
    SW WI
    MT+LB=sport
  12. May 21, 2021 at 6:19 AM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Yep, under a couple hours. As mentioned earlier, I did my own. Spent a whopping $100+ and got the ride I wanted. Still have my OE if I want to go back. Budget does matter for some folks- keep in mind he has an SR.
  13. May 21, 2021 at 6:21 AM
    Taco__Tim
    Taco__Tim [OP] Well-Known Member
    2021 SR DCLB MGM
    Yep, won't be getting anything more expensive than take off OEMs :D.
    I'll see if I can get just the shocks and coils.
  14. May 21, 2021 at 6:37 AM
    Taco__Tim
    2021 SR DCLB MGM
    Would I need to use the OR coils as well or can reuse my SRs?
  15. May 21, 2021 at 7:30 AM
    #35
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Coils match shocks and are different (L/R). It is best if you get the complete Strut, so you don’t have to bother unmounting or changing out hardware. There is a thread here that identifies springs by the color markings. It also identifies the shocks as well.
  16. May 21, 2021 at 7:40 AM
    #36
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    If you are determined to get takeoffs I'd get the OR shocks for the softer ride on rough roads.
