SR sliding rear window part number?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gus, May 31, 2023.
  1. May 31, 2023 at 9:40 AM
    Gus
    Gus [OP] Well-Known Member
    Wayne, Pa.
    2020 Access Cab SR Utility Package Barcelona Red
    Rear sliding window, intermittent wiper switch, center console tray, glove box organizer shelf, WeatherTech front mats and mud flaps, 3D MaxSpider behind-the-front-seats mat, bed lights, MESO climate control rings, XPEL tailgate protection, Desertdoesit.com seat jackers, RAV4 radio knobs, glove box letters.
    Hello everyone. I have a 2020 SR, 4cyl Access cab with a solid, one piece rear window. I'd like to replace it with a manual sliding rear window and was wondering if this is the correct part number: 64810-04111
    I have gotten different numbers from multiple dealerships and want to make sure I order the correct window.
    Appreciate any info!
  2. May 31, 2023 at 12:15 PM
    caribe makaira
    Caribbean, Puerto Rico
  3. May 31, 2023 at 2:35 PM
    Gus
    Wayne, Pa.
    Thank you!
  4. May 31, 2023 at 3:20 PM
    caribe makaira
    Dealership would be best confirmation...
    Gus[OP] likes this.
  5. Aug 3, 2023 at 10:07 AM
    Gus
    Wayne, Pa.
    Got a quote to replace my solid rear glass with an aftermarket slider--$820.00 + tax. That seem fair or high?
  6. Aug 3, 2023 at 10:27 AM
    mi327
    mi327 Member
    A quick search shows the listed Toyota part number selling for around 620.00, adding in labor to remove the old Window and install the new one would put you at about the same cost as you were quoted depending on the shop's labor rate. I would just go with the OEM version at that cost.
    Providing the solid window isn't damaged I would ask for it back and sell it so you can offset some of the cost.
  7. Aug 3, 2023 at 10:29 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    I would pass. You probably won't use it often, esp. since it will be manual open/close.
    Mine is power and I don't ever use it LOL
    Chew and Smunczen like this.
  8. Aug 3, 2023 at 10:46 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    this! That little square isn’t worth the trouble. Really it’s kind of dumb. Also I don’t use it to load long items, don’t need damage to seals or interior parts.
    If you’re dead set on this, I’d call local glass shops, they maybe have aftermarket glass and be more competitive on labor since it’s right in their wheelhouse.
    Gus[OP] likes this.
  9. Aug 3, 2023 at 11:20 AM
    Kenstogie
    Kenstogie Well-Known Member
    Ken
    19 SR 2.7 4x4
    my step father did glass work for many many years and now that he's semi retired he does it on the side for xtra $$$.... any way he says that putting a new sliding glass window is prone to leakage and a PITA. FWIW I have an after market one just sitting in the box.... that I never put in.... I doubt I would have used it even if it were installed. It's to far from the driver to reach with any level of comfort....
  10. Aug 3, 2023 at 3:41 PM
    Gus
    Wayne, Pa.
    Yeah, I can hear my late father saying, 'You're gonna get leaks!' Thanks to all for the input.
  11. Aug 4, 2023 at 4:22 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    I use my slider all of the time. It really helps eliminate the air pressure waves while driving with the front windows down.
    I've never had a slider leak in any of the trucks I've owned. It's also handy has a pass-through for those longer pieces of lumber or pipe I pick up from the hardware stores. Oh, and the dogs love it.
    tl;dr: Access cab. Slider used constantly. Have long monkey arms, so it's easy for me to reach.
    SSMTRDOR likes this.
  12. Aug 4, 2023 at 7:05 AM
    Kenstogie
    Ken
    19 SR 2.7 4x4
    NP, BTW he has a Tacoma (his 3rd I believe) and always has had the sliding back window if memory serves me. He said he rarely if ever uses it.
    If I ever put a shell over the bed and use mine as a Mini/stealth Camper, I think I may like to have the slider so I could access the cab for whatever reason but that's the only instance I can think of....
  13. Aug 4, 2023 at 7:26 AM
    bubbaearle
    bubbaearle Well-Known Member
    N Central Arkansas
    2012 DCSB TSS , 2003 SR 2.4l 5spd, 2023 DCSB SR V6 4x4
    I have a 2012 Tacoma DCSB and have opened the back glass one time in 11 years of owning the truck. I have a new 2023 Tacoma DCSB and prolly won't ever open it either. I actually wouldn't mind replacing it with a solid rear window to ease in cleaning..... It's a pain in the ass cleaning the sliding pane & applying Rain-X without having the corners looking shitty.
  14. Aug 4, 2023 at 8:03 AM
    Gus
    Wayne, Pa.
    I am leaning towards spending my money on keyless entry if I can find a simple solution. That's one thing I do miss from other vehicles I've owned.
    Chew and SSMTRDOR like this.
  15. Aug 4, 2023 at 10:05 AM
    Kenstogie
    Ken
    19 SR 2.7 4x4
    N2 designs remote starter has keyless entry... install yourself. easy.
    Gus[QUOTED][OP] and Chew like this.
  16. Aug 4, 2023 at 11:57 AM
    Gus
    Wayne, Pa.
    Yes, I was curious about the ease of installation but if it's plug and play, I may be sold. Thanks!
  17. Aug 4, 2023 at 10:19 PM
    terryjm1
    terryjm1 Well-Known Member
    Terry
    2023 Tacoma
    I have been debating this as well. If I found a used one at the right price I might give it a go. But, not at $800 ish dollars. If I accidentally broke it I would definitely replace it with a slider.
    Gus[OP] likes this.
  18. Aug 4, 2023 at 10:20 PM
    terryjm1
    Terry
    2023 Tacoma
    I did this and it was really easy. It was well worth the price.
    Gus[QUOTED][OP] likes this.
  19. Aug 5, 2023 at 5:33 AM
    Gus
    Wayne, Pa.
    So, with this remote, you can choose to just unlock the doors and not use the remote start? I don't really see myself using the remote start feature but time will tell.
  20. Aug 5, 2023 at 6:02 AM
    terryjm1
    Terry
    2023 Tacoma
    Yes, just be sure you get one that does both. Some of the add on systems only do remote start.
