SR standard steel wheels
Discussion in '4 Cylinder' started by MJR, Nov 16, 2022.
  1. Nov 16, 2022 at 10:13 AM
    MJR
    MJR [OP] Well-Known Member
    Mickey
    Salado, TX & Santa Rosa Beach, FL
    ‘23 LIMITED 4wd NIGHTSHADE & ‘23 T4R TRD ORP
    Removed factory bed cover and installed UnderCover Elite. Added LOCKERDOWN console safe.
    Is there any reason besides any other wheel looks better to change the standard wheel out?
  2. Nov 16, 2022 at 10:15 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Aluminum weighs less.
    MJR[OP] and ToyoTaco25 like this.
  3. Nov 16, 2022 at 10:15 AM
    Bishop84
    Bishop84 Well-Known Member
    Alloys are lighter and typically wider.
    My steel rims with winters on them weigh almost as much as my summer alloys with heavy all terrains.
    Steels are also prone to rust in the rust states.
    MJR[OP] likes this.
  4. Nov 16, 2022 at 10:52 AM
    AgentCovert
    AgentCovert Well-Known Member
    22 SR5 DCSB 2.7L
    Everything listed above plus fuel economy and less wear and tear on suspension components with less weight far outside at the end of the axles..of course the trade off could be said that a steel rim can take more overall abuse as they are stronger than aluminum and will bend or warp vs cracking and breaking chunks off like an aluminum rim could do..but it's personal taste plus intended use and environmental projected use that plays a factor too..
    MJR[OP] likes this.
  5. Nov 26, 2022 at 7:56 AM
    MJR
    Mickey
    First time seeing them in person and i like the steel wheels
