SR5 Cluster swap into a Base 4cyl T-100
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sitnlow4life, Nov 8, 2016.
  1. Nov 8, 2016 at 6:34 PM
    Sitnlow4life
    Sitnlow4life [OP] Member
    Detroit
    1996 T-100 3RZ
    LCE header , magnaflow high flow cat.
    • I have done this swap on my 1992 pickup without any issues.
      So I figured , what the hell ?
      Let me give it a shot on my T-100, i found a SR5 cluster rather cheap , made sure to get the proper oil pressure sender and adjusted the mileage .
      Boom works perfectly , One issue ....
      Tachometer bounces all over the place when the truck is idling , when you are under load it seems pretty stable but not perfect .
      I realize that this cluster was meant for a 6cyl engine and not a 4cyl.
      I attempted to adjust the pot on the back of the tach , setting it to something similar that i did on my 1992 pickup 63.8K ohms
      Any ideas ? Anyone else come across this ?
      Thanks in advance
