SR5 Engine Failure
Discussion in '1st Gen. Tacomas (1995-2004)' started by RewdDawg, Dec 23, 2010.
  1. Dec 24, 2010 at 1:53 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Just get another 3.4l? The spark plugs probably werent tight and all the combustion pressure was to much for a few threads to hold and it blew out. Not the engines fault someone forgot to tighten its spark plugs. The 3.4's are TANKS and will take whatever kinda abuse you throw at them without missing a beat. If the rest of the truck is in great shape, replace the motor with another 3.4l. :thumbsup:
  2. Dec 24, 2010 at 1:59 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    or just take the head off yourself take it to a machine shop get them to repair the spark plug hole and re-assemble. I mean the heads arent the hardest thing to get off on theses.
    Toyota is just going to take the head to a machine shop. No need to replace the engine for a small repair. I have even heard of people who heli-coil it with the head still on and have no problems.
  3. Dec 24, 2010 at 2:16 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Or take this approach. And save the trouble with a new engine thats not needed.
  4. Dec 24, 2010 at 3:54 PM
    Hogzilla
    Hogzilla Well-Known Member
    Michael
    DFW, Texas
    04 Prerunner sr5
    You could stick a small block ford in it...A small block chevy would be too wide I think.
  5. Dec 25, 2010 at 6:35 AM
    thombiz
    thombiz Active Member
    Corpus Christi
    01 Prerunner & '02 Tundra
    I'm thinking the spark plug is threaded for a distance of about 3/4". If the plug blew out, it would have damaged only about 2-3 of the outermost threads. The threads farther in should still be good. If you can get a visual on the threads, I would check that first. Then you can get a tap from a bolt supply company to match the sparkplug threads, clean up the outer threads and try to put the spark plug back in. It's worth a shot!
  6. Dec 25, 2010 at 6:51 AM
    huntinggunns
    huntinggunns Lifes a garden, dig it.
    Fred
    Oklahoma
    2014 MGM SR5 DC SB TSS 4x4
    In progress
    I'm wth Whitfield on this one. A good machine shop can install the heli coil with out any teardown. There will be no problem running this until the engine finally dies. At that time, have the motor built and install a new/used head and keep on going. A couple hundred dollars vs several thousand dollars, I know which way I would go.
    Fred.
  7. Dec 25, 2010 at 7:36 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Whats it worth if the engine were good, maybe sell it to a salvage yard and buy another truck.
  8. Dec 25, 2010 at 3:51 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    That would be a lot cheaper!
    BUT....I always wanted to do this:
    http://www.dieseltoyz.com/toyota_conversions.html
