sr5 locking differential?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by t-com09, Jan 8, 2012.
  1. Jan 8, 2012 at 7:08 AM
    t-com09
    t-com09 [OP] Well-Known Member
    Connecticut
    2010 single cab 4x4 sr5
    Bilstien 5100's yellow foglights toolbox pop n' lock
    i have a 2010 sr5 with a limited slip differential and am thinking about getting a locking differential instead. has anyone does this?
  2. Jan 8, 2012 at 7:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    Lots of folks have. What kind are locker are you thinking of??
  3. Jan 8, 2012 at 7:18 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You don't have a limited slip differential. The brake system works to make your open differential act like a limited slip. You can add a locker, plenty of people have done it.
  4. Jan 8, 2012 at 7:21 AM
    Brunes
    Brunes abides.
    Rotorhead
    Also a good point...
  5. Jan 8, 2012 at 7:22 AM
    t-com09
    Connecticut
    im not sure. just started looking into it today. any suggestions?
  6. Jan 8, 2012 at 7:25 AM
    Pugga
    Massachusetts
    F-150 Mod
    ARB makes a good one but it works on compressed air. Downside, you have to add an on board air unit, upside, you have on board air for other things like airing back up after a trail or beach run (assuming you air down for off roading).
    You could fit in a locking differential from a TRD Off Road but you need to swap the entire rear end if you want to go that route where as the ARB can be installed into your stock housing and uses your stock gears.
  7. Jan 8, 2012 at 9:03 AM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    I just got a quote from a local driveline shop to drop a Detroit TrueTrac in my '11. $785 complete ($535 parts/$250 labor). I could save by doing this myself, but no thanks. Having them do it gives them the liability for getting it done right and gives me followup warranty coverage. I decided on this vs an air locker because there are no externals to malfunction and it's roughly half the cost.
  8. Jan 8, 2012 at 11:54 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Get a TruTrac especially if your truck is a DD. I have it in my truck and it works great
  9. Jan 8, 2012 at 12:41 PM
    Pugga
    Massachusetts
    F-150 Mod
    Isn't Trutrac just a limited slip though, no ability to lock? Is that really that much different than the traction system that uses the brakes to mimic a limited slip? Seems like if you really need a locked rear end, the truetrac wouldn't be suitable substitute :notsure:
  10. Jan 8, 2012 at 12:50 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Most of those tru trac type lunch box lockers only lock when under power, which is when you need it most of the time.
    If I ever decided I want a locker it will be an ARB though.;)
  11. Jan 8, 2012 at 2:21 PM
    tacos4life
    tacos4life Active Member
    DEE
    Victoria B.C.
    06 6 spd 4x4 trd crew cab shrt box
    6'' fabtech lift 20'' eagle alloys 33x12.5/20 toyo m/t's hid halo headlights billet grill 7'' alpine gps stereo 10"" alpine drop down dvd CAI intake
    Srry for askn a q in ur post but Hey guys I have a open diff and was gonna upgrade to a LSD , is it worth it to switch to a stock trd LSD for a used price + install for 350 I hate how only one wheel spins , if I get the lsd will both wheels spin in the rain on take off ?/snow/gravel exc....
  12. Jan 8, 2012 at 2:29 PM
    tacos4life
    DEE
    Victoria B.C.
    Hmm well I have a stock trd lsd lined up already off of a rolled over truck and it fits into my budget at the time it has 60 000km on it it is from a 07 and my truck is a 06 , dunno if I should get it but I'm sure it's better than my open diff because my truck just has the sr5 package
  13. Jan 8, 2012 at 2:33 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    a non selectable rear locker is a BAD idea for a DD vehicle, it is not safe. it will "lock up" when making a turn which can lead to a spinout or loss of traction..it will cause driveline bind on pavement..making a u-turn on pavement can make the rear tires literally hop off the ground..
    i have a Detroit non selectable front and rear locker in my rockcrawler, so i can tell your first hand that the driving attributes and characteristics of a non selectable rear locker sucks ass in the rear on a DD.
    i would suggest that you look into an actual LSD unit or the ARB air actuated selectable rear locker as your true choices!!
  14. Jan 8, 2012 at 2:34 PM
    tacos4life
    DEE
    Victoria B.C.
    Thx for the info I went and checked it out today I was contemplating buying the whole axle and doin a axle swap or just the diff and use my existing axle housing , what would be the better choice?
  15. Jan 8, 2012 at 2:37 PM
    06indigoink
    06indigoink Well-Known Member
    Charlotte NC
    06 4x4
    I have a powertrax no slip in mine, chirps the tires sometimes when I turn but nothing really dangerous unless u stomp on the throttle. Installed it myself too. Not to bad of an install
  16. Jan 8, 2012 at 2:54 PM
    tacos4life
    DEE
    Victoria B.C.
    Whippersnapper:Ye both trucks are v6 only difference is his was auto and long box mine is 6spd with shrt box does that complicate things or is it the same ?
  17. Jan 8, 2012 at 3:04 PM
    06indigoink
    Charlotte NC
    06 4x4
    Depends on what gear ratio it had, and what urs has
  18. Jan 8, 2012 at 3:09 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    All 05+ v6s have 3.73 gears, aside from the xrunners.
  19. Jan 8, 2012 at 3:11 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    My factory LSD on 07 sr5 has been amazing.
  20. Jan 8, 2012 at 10:47 PM
    tacos4life
    DEE
    Victoria B.C.
    Cool thx for the info guys much appreciated and I do believe u jhodge but how exactly can I find out the ratio to double check? Take vin into dealership or stick my head down there and read the outside of diff housing?
