SR5 Remote Start - 1H Connector 90980 – 12944 Pin Size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YotaC, Jan 25, 2023.
  1. Jan 25, 2023 at 9:02 AM
    YotaC
    YotaC [OP] Member
    Does anyone know what the pin type/size is for the 1H connector? Specifically pin number 33.
  2. Jan 25, 2023 at 9:05 AM
    YotaC
    YotaC [OP] Member
  3. Jan 25, 2023 at 1:11 PM
    caribe makaira
    Caribbean, Puerto Rico
    Not 100% sure but you could try: TE1827855-2
    TnShooter likes this.
  4. Jan 25, 2023 at 1:15 PM
    caribe makaira
    Would you post a pic of the top side of the terminal (pin)?
  5. Jan 25, 2023 at 4:46 PM
    YotaC
    YotaC [OP] Member
  6. Jan 25, 2023 at 4:47 PM
    YotaC
    YotaC [OP] Member
    It is 1.5mm wide
  7. Jan 25, 2023 at 4:51 PM
    caribe makaira
    .5 too large...bummer or measured incorrectly?
  8. Jan 25, 2023 at 5:10 PM
    YotaC
    YotaC [OP] Member
    This is where I am measuring
  9. Jan 25, 2023 at 5:13 PM
    caribe makaira
    :notsure:
    The search continues...
  10. Jan 25, 2023 at 5:23 PM
    YotaC
    YotaC [OP] Member
  11. Jan 25, 2023 at 5:35 PM
    Bishop84
    Bishop84 Well-Known Member
    I suck at this. Edit again.
    82998-24290
    Ok, I'm fairly confident on this #. I'm giving up now.
    Hopefully a dealer has this in stock and you can compare.
    davidstacoma likes this.
  12. Jan 25, 2023 at 6:55 PM
    YotaC
    YotaC [OP] Member
    Much appreciated! I'll check with my local dealer tomorrow.
  13. Jan 25, 2023 at 7:12 PM
    caribe makaira
    Does it match?
  14. Jan 25, 2023 at 7:19 PM
    YotaC
    YotaC [OP] Member
    I think that is it exactly. It even has the same faint logo stamped on the base.
  15. Jan 25, 2023 at 7:21 PM
    caribe makaira
    No macro camera settings for a proper pic?:burp:
  16. Jan 25, 2023 at 7:24 PM
    YotaC
    YotaC [OP] Member
    Ha. I'll do my best but it is hard to focus.
    Web link for the image?
  17. Jan 25, 2023 at 7:27 PM
    caribe makaira
  18. Jan 25, 2023 at 7:30 PM
    YotaC
    YotaC [OP] Member
    Nice.
    I installed a remote start and I am trying to avoid cutting the TPMS wire. So I am making an adapter for it.
  19. Jan 25, 2023 at 7:40 PM
    caribe makaira
    Which wire in the TPMS circuit you need to intercept?
  20. Jan 25, 2023 at 9:06 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Small terminals are Sumitomo TS 0.64 mm, larger terminals are TS 1.5 mm. Part numbers for various wire sizes/plating (Toyota repair wires in parentheses):
    8100-3624 - 0.64 mm, 0.22 - 0.35 mm² Wire Size, Copper Terminal/Tin Plated
    8100-3625 - 0.64 mm, 0.3 - 0.5 mm² Wire Size, Copper Terminal/Tin Plated (Toyota Repair Wire 82998-24290)
    8100-3628 - 0.64 mm, 0.22 - 0.35 mm² Wire Size, Copper Terminal/Gold Plated
    8100-3629 - 0.64 mm, 0.3 - 0.5 mm² Wire Size, Copper Terminal/Gold Plated (Toyota Repair Wire 82998-24300 or 82998-24390)
    8240-0182 - 0.64 mm, 0.13 mm² Wire Size, Copper Terminal/Tin Plated
    8240-0338 - 0.64 mm, 0.13 mm² Wire Size, Copper Terminal/Gold Plated
    8240-0213 - 1.5 mm, 0.75 - 1.25 mm² Wire Size, Copper Terminal/Tin Plated (Toyota Repair Wire 82998-52030)
    8240-0214 - 1.5 mm, 2.0 mm² Wire Size, Copper Terminal/Tin Plated (Toyota Repair Wire 82998-24350)
    8240-0215 - 1.5 mm, 0.3 - 0.5 mm² Wire Size, Copper Terminal/Tin Plated (Toyota Repair Wire 82998-12A10)
    8240-0279 - 1.5 mm, 0.22 - 0.35 mm² Wire Size, Copper Terminal/Tin Plated
    8240-0339 - 1.5 mm, 0.13 mm² Wire Size, Copper Terminal/Tin Plated
    Jeff
