SR5 shocks to 5100s - How much difference in feel?
Discussion in 'Suspension' started by Bobcat, May 27, 2010.
  1. May 27, 2010 at 8:21 PM
    Bobcat
    Bobcat [OP] Well-Known Member
    Montana
    I have non trd shocks in the front and regular trd bisteins in the back. Why, that is a different discussion, but anyway I dont mind the ride right now. Its fairly soft, but I succumbed to temptation and got 5100s for each corner. Now I am having second thoughts. I know they are better but will it be alot rougher ride? I hear all sorts of opinions, and I guess it depends on peoples expectations, but I still would like people's opinion. Maybe from someone who had regular sr5 shocks and went to 5100s
    Second question. I hit the bump stops more than I would like. I dont have, or qualify for the TSB so my option is a AAL. Question is if I dont want to sacrifice ride comfort by adding the AAL will the 5100s help not hit the bump stops as much? I would think so.
  2. May 27, 2010 at 8:42 PM
    B_brand
    B_brand Well-Known Member
    Brandon
    Oklahoma
    Why don't you qualify for the TSB?
  3. May 27, 2010 at 8:59 PM
    Bobcat
    Montana
    You gotta be under warranty still.
  4. May 28, 2010 at 5:48 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I have billys in the back, but I can't comment on the ride vs. sr5 because I installed them the same day I got my leaf spring tsb done. So the ride is a little bit stiffer, but I like it better...doesn't ride like a station wagon anymore.
    If you are planning on doing the install yourself (install on the rear shocks is real easy), I'd say throw them on there and see how you like it. Worst-case scenario you can take them off. The whole install only takes about 30 minutes.
  5. May 28, 2010 at 5:59 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    the 5100's will give you a BETTER ride. if you set the fronts at .85 it should still ride like factory. i would get a 1" AAL and set at .85 and youll be much better than stock. if you want more lift and dont mind a little stiffness get a 1.5"AAL and set the fronts to 1.75
  6. May 28, 2010 at 6:10 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I had the stock black shocks on the back of my truck with a single AAL and it rode so rough! I got the 5100's and it didnt change much. then I swapped out my AAL and got the wheelrs 3 AAL pack. Its soo much smoother now and Im very happy with it.
  7. May 28, 2010 at 7:02 AM
    Bobcat
    Montana
    That is interesting. I assume the wheelers pack doesnt have the big overload leaf, and that is the difference?
    Also, another poster said that you can get a 1 inch aal. I have not seen one. Who sells these?
  8. May 28, 2010 at 7:46 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I think toytec sells the 1" but not sure.
    yea, the wheelers pack adds 3 leafs but you remove the OL leaf. Its great, its a really soft ride and Im still able to haul crap if I need to, not as much as before...but that wasnt a concern. but this 3 leaf pack kept me at the same height in the rear as the single all plus the OL leaf. so minus 2, plus 3 and im still the same height
  9. May 28, 2010 at 11:59 PM
    Bodete
    Bodete Well-Known Member
    Missouri
    2018 Tacoma TRD Off Road
    I had the stock sr5 shocks and up graded to the 5100's front and rear. On the front I also added eibach springs and set the 5100's to 0 which gave me a 1.25" lift in front. It was a big difference. It's much better, the ride is firm but not stiff. The stock suspension is too soft. I don't have the TSB done yet. I'm getting it done next week. I would recommend the 5100's.
  10. May 29, 2010 at 11:19 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    I went from SR5 shocks to 5100's set at 2.5. I love them. I don't slam my head into the window when I pull into a rough parking lot now :D
  11. May 29, 2010 at 5:53 PM
    Bobcat
    Montana
    IF you set them at zero and still got 1.25 of lift then the lift must be in the springs? Just curious.
  12. May 29, 2010 at 9:38 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    i have 5100s up front only, and starting to believe its a bit too hard for my liking and would consider going to trd bilsteins all around. granted i also swapped in trd off road coils at the same time upgrading from my regular shocks and reg coils.
    its my work truck that i drive about 500 miles a week in around town and highway, id like for it to be as comfortable as can be.
  13. May 29, 2010 at 9:39 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    HUGE difference especially while on washboard roads
  14. May 30, 2010 at 9:45 PM
    Bodete
    Missouri
    Yes the 1.25" lift was from the springs. From everything that I read prerunners get about 1.6" lift and the 4x4 gets only around 1" of lift with the eibach springs and 5100's set to 0. I guess the front end is heavier on the 4x4.
  15. May 30, 2010 at 9:52 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    Going from stock to 5100s will be like night and day difference. You will love it.
