SR5 TRD DRL Headlight harness? Please?
Discussion in 'FBC Harness Solutions' started by Guyofsteele, Feb 20, 2024.
  1. Feb 20, 2024 at 5:07 PM
    Guyofsteele
    Guyofsteele [OP] New Member
    Michael
    2022 Tacoma SR5
    2022 Tacoma SR5 TRD pro grill, grill lights, TRD off road Headlights.
    Hey FBC Solutions,
    I have been running around online in search for a harness to equip my DRL TRD LED off road headlights into my 2022 SR5. I did read on your website that you would stop producing the harness. I am respectfully requesting to know if for a special order I can acquire a harness to run the headlights in my SR5? I can pay special pricing if need be, but this would be a huge ask and a even greater favor for a desperate customer. Thank you for your time and consideration.
  2. Feb 20, 2024 at 5:18 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
  3. Feb 20, 2024 at 6:13 PM
    Guyofsteele
    Michael
    2022 Tacoma SR5
    Thank you sir. However I am confused because all i see are 4 plugs for the headlights...The TRD headlights installed on my 2022 SR5 have 5 plugs?
  4. Feb 20, 2024 at 8:00 PM
    daveeasa
    David
    PNW
    Read the thread. It’s not a product from me.
  5. Feb 20, 2024 at 8:10 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    I can help. The reason you see 4 plugs (I assume you are counting the plug to the headlight itself as well) is on the SR5, there are plugs for high and low beam, and a plug for the DRL/turn signal. The last plug on the SRs is for the sidemarker. When you convert to the LEDs, the side marker is redundant, so it just gets capped. You said that you have TRD lights on your SR5 though with 5 plugs? The SR5 didn’t come with TRD lights originally. If it does have 5 plugs (high, low, DRL, turn signal, and sidemarker) then it sounds like it has either been converted or you have a TRD trim like a sport or Offroad? Do your existing headlights have a white “L” shaped DRL that goes around the side and bottom of the main beams?
  6. Feb 20, 2024 at 8:14 PM
    Puppypunter
    Johnny
    2019 Black SR
    Wait, I’m an idiot. You want to put TRD lights on your SR5! Sorry, I’m slow sometimes :rofl:. I do still make a harness for that. It will convert the combined Turn/DRL on the SR5 to a separate DRL and Turn signal. The low, high, and sidemarker on your SR5 are the same plugs as the TRDs, so those just get reused, no adapting required. Shoot me a PM, and we can make sure to get you what you need
  7. Feb 20, 2024 at 8:18 PM
    daveeasa
    David
    PNW
    I read that as a question, “do my headlights actually have 5 plugs?” The answer to that would be, no.
    I think this is a straight up OEM LED SR5 conversion harness. But OP could post photos to confirm. One of the old headlights and one of the new.
  8. Feb 20, 2024 at 8:58 PM
    Puppypunter
    Johnny
    2019 Black SR
    Hopefully @Guyofsteele will let us know which headlights he has and which he is looking to install :) Either way, I’ll take care of him.
  9. Apr 16, 2024 at 10:00 AM
    littlebigtownusa
    littlebigtownusa Member
    Salem, Oregon
    I believe this is the harness I need. My 2023 Trail (SR) has 4 plugs, and I would like to install OEM LED DRL Headlights with 5 plugs. Will send PM now.
