Sr5 vs Offroad suspension
Discussion in 'Suspension' started by skiroc, Dec 13, 2021.
  1. Dec 13, 2021 at 9:40 PM
    skiroc
    skiroc [OP] New Member
    I'm looking to get a 3rd gen Tacoma to carry an FWC camper. Focusing on suspension to carry the 1200 lbs, what is the difference in the stock suspensions between the SR5 and Offroad? Doing a build compare on the Toyota site, it does not list any differences. I don't need most of the stuff on the Offroad, so will likely go with the SR5 if suspensions are the same, knowing I will need to make mods anyway.
  2. Dec 13, 2021 at 9:42 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Probably doesn’t really matter
    you’re gonna need to change it anyway
    DavesTaco68 likes this.
  3. Dec 13, 2021 at 9:44 PM
    airmax233
    airmax233 Always ready for the next adventure
    Southern California
    12 PreRunnerTrd sport R.I.P 21 Tacoma Off road 4x4
    2.5 Kings w/resi Adj. Total Chaos Upper control arms. IG: Cement_runner23
    If you are going to carry 1200 lbs at that point you already have to swap out leaf pack and suspension. I’d go with the sr5 since you don’t want/need what the offroad has and save a few grand.
  4. Dec 14, 2021 at 3:02 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    The suspension is the least of what you should be considering between a SR5 and an OR. The OR has Crawl control, and the Locker those are the biggest reasons to get the OR. Suspension? Eh? More than likely you'll change it out anyways. Or you probably can find it really cheap on CL.
  5. Dec 16, 2021 at 11:06 AM
    dirt_seeker
    dirt_seeker Well-Known Member
    Utah
    2017 TRD OR
    Forget the OR the extra bits on the OR it does not sound like you will use or want. With either model you will need to change the suspension so just go with the SR5, the money you will save will pay for most if not all the suspensions upgrade.
  6. Dec 16, 2021 at 12:46 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The only thing different is the shock absorbers. The GVWR of all the trims is the same. The payload capacity varies based on how heavy the options are.
