SR5 vs TRDOR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ilkhan, Jul 23, 2017.
  1. May 27, 2020 at 10:51 AM
    #41
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    It's the size of the ring gear (8 vs 8.75 I think). In general the bigger the ring gear the stronger it is.
  2. May 27, 2020 at 10:55 AM
    #42
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Yeah, outside diameter of the ring gear is what is actually measured. Sorry, I didn't clarify that in my response. Obviously this also makes the differential itself larger to house the larger gear.
    boston23 likes this.
  3. May 27, 2020 at 10:58 AM
    #43
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    The Off-road and all manual transmission 3rd gens have an 8.75" diff instead of the 8" you'll find on the others. It's my understanding that the axle is the same size just the ring gear is different.
    The gear ratio is different for manuals and automatics. V6 3.5 trucks with automatic have 3.90 and the manual has 4.30. Those ratios are reversed for the I4 2.7L.
  4. May 27, 2020 at 12:59 PM
    #44
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    And carrier size.
