SRS Light on
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shennanigans, Oct 25, 2016.
  1. Oct 25, 2016 at 12:45 PM
    Shennanigans
    Shennanigans [OP] Well-Known Member
    Eric
    2001 TRD prerunner sr5 rwd
    none.... yet
    Hey guys.
    My srs light just came on (not flashing, just on all the time) It has gone off briefly a few times, but only to come back on. Due to this I think its a loose connection that i just need to re secure. Do any of you have any experience with this? Or know how i can find where the connections are and make sure theyre all plugged in? Or would it just be easiest to find someone who can read the codes for me?
    Before it's suggested, the clock spring is fine. I put a new one in recently, and my horn/ cruise control still work, so i doubt that it is the issue.
  2. Jan 6, 2017 at 11:16 AM
    MainerDave19995VZ
    MainerDave19995VZ Well-Known Member
    David
    Maine
    1999 Tacoma Extra Cab SR5 TRD 5 Speed 5VZFE
    2nd generation 16" wheels with 1.25" BORA spacers
    I found this:
  3. Jan 6, 2017 at 11:18 AM
    MainerDave19995VZ
    David
    Maine
    I'm looking at buying a 1999 PreRunner with the SRS light on. This might be an inspection issue here in Maine. I'm trying to figure out my best troubleshoot options so I don't miss the fact that its the airbag itself or an undisclosed accident.
  4. Jan 6, 2017 at 12:00 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    bad connections usually occur on the sensors of the SRS system:
    crash sensors at the front of the truck (they sometimes corrode and go bad)
    passenger airbag on-off switch
    sensors under the seats
    seatbelt pretensioners
    clockspring (but it is not your issue, as you changed yours not so long ago)
    Can also be SRS ECU or the airbags themselves but it is rare to see these failing
    If you want to be sure of which one it can be, get error codes pulled out of the truck
    MainerDave19995VZ likes this.
  5. Jan 6, 2017 at 12:04 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Can you get it to a dealer? They can scan it and tell you what part of the system is causing the light to go on.
  6. Jan 6, 2017 at 8:17 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Electrical tape on the dash mod...:)
    But seriously, the above is solid advice.
  7. Jan 15, 2017 at 2:13 PM
    Shennanigans
    Eric
    none.... yet
    if you can get a scanner on it it'll tell you. thats how i was certain mine was the clockspring
