SRS Light won't go out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bkthompson6, Feb 27, 2010.
  1. Feb 27, 2010 at 8:33 PM
    bkthompson6
    bkthompson6 [OP] Well-Known Member
    Brandon
    Oregon
    My Safety Restraint System light is staying on....... Any recommendations other than taking it to the stealership? Thanks guys
  2. Feb 27, 2010 at 8:37 PM
    tussery
    tussery Well-Known Member
    Corpus Christi, Tx
    09 PreRunner SR5
    Magnaflow muffler, TRD CAI.
    Sadly the answer is take it to the dealer.
  3. Mar 1, 2010 at 2:37 PM
    bkthompson6
    Brandon
    Oregon
    Anybody else have any answers?
  4. Mar 1, 2010 at 2:39 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    have you installed an amp or anything to your truck?
    ive had the same problem with my 08. I took it in once and they said it may just be a malfunctioning light. Kept commin on and off so i took it in again and they pulled apart my interior and said that my power cable running to my amp is messing with the seat sensor. 40 bucks in labor to pull apart my cab...(good joke) and i had to move my wire and it seems to have fixed the problem
  5. Mar 1, 2010 at 2:46 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I had that problem a while back. The plug under the driver's seat was partially disconnected. Pushed them together and problem was solved. Hope that's what it is.
  6. Mar 1, 2010 at 2:58 PM
    bkthompson6
    Brandon
    Oregon
    Come to think of it, i just put in a CB. Maybe that has something ot do with it.
  7. Mar 1, 2010 at 2:59 PM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    prob clock spring thats why mine is on and havent replaced it yet to expensive
  8. Mar 1, 2010 at 3:01 PM
    bkthompson6
    Brandon
    Oregon
    Clock Spring?
  9. Mar 1, 2010 at 3:06 PM
    brians05taco
    Brian
    Lafayette,La.
    it triggers your airbags located in steering wheel assembly.... i was told as long as i got in an accident and my wheels were strait they would blow, if wheels are turned they will not blow
  10. Mar 1, 2010 at 3:06 PM
    brians05taco
    Brian
    Lafayette,La.
    around 500 dollars to fix at toyota, may not be your problem have them put it on there computer
  11. Apr 2, 2010 at 9:06 AM
    bkthompson6
    Brandon
    Oregon
    So, finally got it in to the stealership. Of course the first thing they try to blame it on without even looking into the problem was my CB radio (i swear they look for anything aftermarket as a scape goat). So $150 to diagnose the prob... the tech said that someone has been under the seat f-ing around, and one of the wires is grounded out, which in turn shorted out the control box between the two seats. I dont get it because the light wasn't on when i bought the truck, whatever. He quoted me $850 to fix it... needless to say, I won't have working airbags for a while. My '93 toyota didnt have airbags and (knock on wood) i didnt get into any accidents. Hope this truck will have the same story.
  12. Apr 2, 2010 at 9:15 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    06 TRD Prerunner
    I'll have to remember that.... ONLY crash while going straight.
    The "clock spring" is a coiled wire that allows the airbag and stereo controls to be hooked to the steering colum and not twist and break when you turn the wheel. Your airbag can and will deploy regardless of steering wheel position.
  13. Apr 2, 2010 at 9:20 AM
    bkthompson6
    Brandon
    Oregon
    Well the dealership told me that the airbags would not deploy at all it the SRS light is on, it disengages them i guess
  14. Apr 2, 2010 at 9:29 AM
    GSRON
    Ron
    Northern CA
    06 TRD Prerunner
    That's true SRS lite = no airbag. On some of the European cars I work on the system is smart enuf to know where the problem is and only turn that portion off. Our trucks aren't that smart yet.......
  15. Apr 3, 2010 at 8:26 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    The problem can be pinpointed if you take it to the dealer or and independent garage capable of reading the code. No point wasting all that time trying to find the problem - there are literally dozens of possibilities.
  16. Apr 3, 2010 at 8:42 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
    Are you sure? I have had my light diagnosed, and its the clock spring, and my horn works fine...
  17. Apr 3, 2010 at 2:13 PM
    bkthompson6
    Brandon
    Oregon
    They already pinpointed it, its a ground under the seat... if you guys are trying to help me out.
