SRS Warning light After Taking apart steering wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ryanl2425, Aug 11, 2016.
  1. Aug 11, 2016 at 11:46 PM
    ryanl2425
    ryanl2425 [OP] Doesn't work..Hit with hammer...Then hit harder
    Truckee, CA
    2015 MGM Tacoma DCSB Prerunner
    I had the SRS warning light go on after I took apart the steering wheel to paint the spokes and the light whent on. Does anyone know the reason or how to fix it?
  2. Aug 12, 2016 at 4:32 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    You probably didn't connect the air bag up properly. Make sure you push down the little tabs on the air bag connectors.
  3. Aug 12, 2016 at 4:53 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Take it back apart to see what wasn't put back correctly... Then correct your errors.
    We have no way to know what you did or didn't do. :frusty:
  4. Aug 12, 2016 at 5:09 AM
    98tacoma27
    Ben
    Not Beech Creek
    Disconnect the battery when you do
  5. Aug 12, 2016 at 4:06 PM
    ryanl2425
    Truckee, CA
    Thanks man you were right the connector wasn't in properly
    Ruggybuggy[QUOTED] likes this.
