SS5 7 POD CROSSLINK - Harness getting hot and burning relays…
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TegoTaco, Jul 21, 2024.
  1. Jul 21, 2024 at 3:40 PM
    TegoTaco
    TegoTaco [OP] Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    So I finally got around to wiring the SS5 7 POD CROSSLINK, built my own relay harness using 10awg wiring, 80amp rated relay, have inline fuse rated at 50amps from the battery. I used one of the ground locations on the passenger side engine compartment. Also, noticed a slight flicker to the lights as well when they were on.
    The positive wire from the battery and the power wire from the LED bar gets pretty hot, burned to relays. I was trying to save myself a few bucks by not purchasing the $200cad harness from Diode Dynamics but it looks like I have to if I can’t figure it out.
    These are the specs for a single pod.
    I am stumped, I’ve never had any like this happen before so this is a first for me lol!
  2. Jul 21, 2024 at 9:05 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    First off there's no way that relay can handle 80 amps, it looks like a standard Bosch style 4/5 pin relay which are good for no more than 30 amps maybe 40 at most for short periods.
    The lights look to be rated at 6.25 amps each, you have 7 of them so that's almost 44 amps.
    BKinzey, SR-71A and deanosaurus like this.
  3. Jul 22, 2024 at 4:06 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Start with a reputable relay. A Bosch P/N 0986AH0082 is rated to 70A, and you can actually believe what it says on the tin.
    Here's a link to a listing on Uncle Jeff's Chumbucket - https://www.amazon.com/0986AH0082-Operating-Temperature-Degree-without/dp/B07CQY3LSB
    I have seen more problems with over-rated (in the electrical sense) relays and transformers than I could possibly keep track of, and when you start looking at stuff advertised explicitly as "automotive" and sold at a bargain price point, you are wading into a supply chain that is absolutely rife with shoddy, mislabeled, defective, and underbuilt components. Some of that price delta is the brand name tax, and there are definitely instances of "the same thing for less money", but that is less and less frequent these days.
    BKinzey and BabyBilly like this.
  4. Jul 22, 2024 at 5:34 AM
    TegoTaco
    Ontario, Canada
    Since the relay can’t handle the load, would that cause the positive wires to get hot and the lights to have a slight flicker to them?
  5. Jul 22, 2024 at 5:45 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Even your 10 AWG isn't rated for what you are trying to do..
    llibrm, AllTacosFloat and BabyBilly like this.
  6. Jul 22, 2024 at 6:00 AM
    TegoTaco
    Ontario, Canada
    Whats weird is, Diode Dynamics sells the harness with 10awg wiring. :confused:
  7. Jul 22, 2024 at 6:21 AM
    TegoTaco
    Ontario, Canada
  8. Jul 22, 2024 at 6:53 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Their own math doesn't add up.
    "Power's 5-8 pods"
    6.7 amps per pod
    Thats 33.5-53.6 amps
    "Harness poweres up to 45 amps of auxilary lights"
    BabyBilly and SR-71A like this.
  9. Jul 22, 2024 at 7:01 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Is your wiring pure copper or Copper Clad Aluminum (CCA)? CCA is crap wire, but it's cheap :rolleyes: If it doesn't say, it's probably CCA. Flickering or pulsing lights, when they aren't supposed to, often is a sign the wiring is overloaded.
    deanosaurus likes this.
  10. Jul 22, 2024 at 7:39 AM
    TegoTaco
    Ontario, Canada
    it does say aluminum on it.
    1 says it’s rated for 6 amps per pod while the other says 6.7. If it’s true, it’ll be 42 amps with 7 pods but at 6.7amps it will be almost 47 amps.
    Just checked, it’s CCA.
  11. Jul 22, 2024 at 8:09 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    That's a good point. 10 gage is only good/safe for 30 amps.
  12. Jul 22, 2024 at 8:18 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 Pro
    You also shouldn't be aiming to just barely cover the requirements of your system. Add 10-15% to whatever the system requirements are as a buffer for your wiring and relays.
    caribe makaira likes this.
  13. Jul 22, 2024 at 5:24 PM
    caribe makaira
    Caribbean, Puerto Rico
    Divide the lights into 2 sets on the wiring side. Lowers the total amps per DIY harnesses.
    Dm93 and BabyBilly like this.
  14. Jul 22, 2024 at 5:58 PM
    caribe makaira
    BabyBilly and Dm93 like this.
