SSC1 1" LED Pods | Diode Dynamics
Discussion in 'Diode Dynamics' started by Diode Dynamics, Mar 8, 2022.
  1. Mar 8, 2022 at 12:25 PM
    Diode Dynamics
    Diode Dynamics [OP] Automotive Lighting Experts Vendor
    St. Louis, Missouri
    Diode Dynamics is pleased to offer our Stage Series 1" LED Pod!
    https://youtu.be/KroHNRvirz4
    Featuring custom-engineered TIR optics combined with a single high-power LED chip, these pods have been designed for maximum performance and light output, in our most compact, versatile package yet. The SSC1 can be mounted virtually anywhere on your car, truck, motorcycle, or UTV, including spots where larger LED pods won't fit.
    Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in the Stage Series 1" collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency.
    From there, while other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the Stage Series C1 serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of the SSC1 is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
    Functional Patterns.
    All Stage Series beam pattern options were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern. No matter what your auxiliary lighting needs are, there is a Stage Series optic for you!
    • Flood pattern was designed to provide uniform, even illumination with a full 50x50 degree spread of light. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout. It is perfect to use as a backup light, scene lighting, or for trailers and roof racks.
    • Wide pattern is perfect for general illumination. It spreads light a full 50 degrees, but keeps a tighter 20-degree vertical spread. It has a slight punch, but still fills out the area. The Wide pattern can be used anywhere you need to shine some extra light!
    • Spot is an unmodified pattern, shining focused light directly from the TIR optic. The result is a highly-focused 7-degree beam of light, perfect for directing light far into the distance.
      Note: The Pro Spot uses a slightly larger emitter which spreads the light output more than the Sport Spot, resulting in a lower candela and lux rating even at a higher power level.
    • SAE Fog provides an extremely wide field of view, with high-intensity output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle.
    Interchangeable Lens. Need a different beam pattern or color? You can swap it yourself! We offer replacement lenses that allow you to change the color or optic of your Stage Series SSC1 Pods.
    Snap-on covers. For states that require them, or for extra styling or protection, we also offer snap-on covers for your SSC1 Pod. These covers are available in a variety of colors and keep your SSC1 Pod clean and protected from dirt, dust, or whatever else the road throws your way!
    Please check your local laws and regulations for aiming, installation, and applicability.
    Click HERE to shop interchangeable SSC1 lenses!
    Click HERE to shop SSC1 snap-on covers!
    White or Yellow. All Stage Series LED pods are available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road.
    Sport or Pro. Stage Series LED pods are available at two different power levels. Both options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. However, the Pro option is double the amount of total power.
    Backlight Functionality. The Stage Series 1" LED Pod includes a distinctive backlight feature, in your choice of white, amber, red, and blue.
    The SSC1's backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
    NOTE: Due to the yellow lens, the Yellow SSC1 LED pod is only available with an Amber backlight color.
    In the Box:
    • Two (2) Stage Series 1" LED Pods
    • Two (2) Deutsch-style wire pigtails
    • Two (2) Mounting brackets and hardware
    Simple connections. All Stage Series 1" LED pods feature a custom-molded DT type Deutsch-style connector on the back, and come with a 6-inch pigtail with bare leads. For installation, you can wire yourself, use an off-the-shelf Deutsch DT sized wire harness, or select an optional Diode Dynamics wire harness. Our Light Duty Dual Output 4-Pin Harness can be used to power up to four SSC1 pods.
    Proven Reliability. Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
    If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
    PM us for the free-shipping code (U.S. forum members only)
    John C.
    Diode Dynamics
    Customer Installed Images:
    Roof Rack Mounted (Auxilary Lighting)
    Bed Rack Mounted (Auxilary Lighting)
    Rear Bumper Mounted (Reverse Lighting)
    Custom SSC1 LED Pod Light Bar
    Gunshot-6A likes this.
  2. May 10, 2022 at 11:42 AM
    Diode Dynamics
    St. Louis, Missouri
  3. May 17, 2022 at 2:04 PM
    Diode Dynamics
    St. Louis, Missouri
  4. May 26, 2022 at 12:55 PM
    Diode Dynamics
    St. Louis, Missouri
    Diode Dynamics’ Memorial Day Sale is going on NOW through Friday, 6/3.
    Get 15% off all LED lighting upgrades with code "USA22" during checkout!
    Plus, all orders over $300, will receive FREE shipping.
    Click HERE to shop Diode Dynamics LED Lighting products!
    Note: Products on pre-order (Elite Series Fog Lamps) are excluded from this sale.
  5. Jun 3, 2022 at 8:10 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    @Diode Dynamics for the SAE option with the wide and short fog pattern, is it possible/necessary to rotate the lens 90* if mounting sideways to keep the orientation correct?
    Looking to put a pair on my KTM, and I don't think they'll fit upright in the spot I want them.
  6. Jun 3, 2022 at 1:48 PM
    Diode Dynamics
    St. Louis, Missouri
    Don't miss your chance to save 15% off your entire order of lighting upgrades!
    Coupon Code: USA22
    Plus, get FREE shipping when you spend $300! HURRY, this sale ends TONIGHT!
    Click HERE to Shop!
    Sale ends 11:59 p.m. CST | Friday, 06/3/2022.
    Note: Items on pre-order are exempt from the sale.
  7. Jun 3, 2022 at 2:29 PM
    Diode Dynamics
    St. Louis, Missouri
    The TIR optic is designed with a notch to keep from orientating the optic. However, if you file the small notch on the SSC1 TIR optic the lens is able to rotate to correct the beam pattern.
    Many customers have performed this simple modification but it does void our included 8-year warranty if any issue arises.
    Gunshot-6A[QUOTED] likes this.
  8. Jun 3, 2022 at 3:16 PM
    Gunshot-6A
    Conner
    Everett, WA
    Thanks for the follow up!
  9. Jun 6, 2022 at 8:19 AM
    Diode Dynamics
    St. Louis, Missouri
    You're welcome!
  10. Jul 5, 2022 at 10:21 AM
    Diode Dynamics
    St. Louis, Missouri
    THE CLOCK IS TICKING!
    Hurry! There are ONLY 3 DAYS LEFT to save on your favorite LED lighting products from Diode Dynamics.
    Click HERE to shop!
    John C.
    Diode Dynamics
    Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes.
  11. Jul 8, 2022 at 1:32 PM
    Diode Dynamics
    St. Louis, Missouri
    ALERT: LAST CHANCE TO SAVE 15% OFF!!!
    COUPON CODE:
    JULY4
    Plus, all orders over $300 will receive free US shipping!
    Don’t wait...this sale ends TONIGHT!
    Click HERE to Shop!
    John C.
    Diode Dynamics
    Sale ends 11:59 p.m. CST on Friday, 7/8/2021. Cannot be combined with other coupon codes.​
  12. Jul 18, 2022 at 12:42 PM
    Diode Dynamics
    St. Louis, Missouri
  13. Aug 12, 2022 at 9:01 AM
    Diode Dynamics
    St. Louis, Missouri
  14. Sep 1, 2022 at 10:49 AM
    Diode Dynamics
    St. Louis, Missouri
    Our Labor Day Sale starts NOW! Today through Friday, 9/9/2022, save 15% on all LED upgrades by entering coupon code "LABOR22" at checkout!
    Plus, all orders over $300 will receive free US shipping.
    Click HERE to Shop!
    John C.
    Diode Dynamics
    Sale ends 11:59 p.m. CST on Friday, 9/9/2022. Cannot be combined with other coupon codes.
    Bee Finn likes this.
  15. Nov 21, 2022 at 8:47 AM
    Diode Dynamics
    St. Louis, Missouri
    Our Black Friday Sale is LIVE! Visit the website for our BIGGEST savings ever!​
    20% OFF Sitewide
    30% OFF Stage Series Single-Row Lightbars
    15% OFF Elite Series Headlights
    ➡ Free US Shipping on any order with a HitchMount LED Pod, or orders over $300.
    No coupon code is required.
    Click HERE to shop!
    John C.
    Diode Dynamics
    Sale ends 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.​
  16. Nov 28, 2022 at 1:03 PM
    Diode Dynamics
    St. Louis, Missouri
    Our BIGGEST and FINAL sale of the year ends tomorrow 11/29 at 11:59 pm CST!
    20% OFF Sitewide
    ➡ Plus, orders over $300 receive free US shipping!
    Excluded Products:
    Hitch Mount LED Pods (Includes free US shipping)
    CLICK HERE TO SHOP!
    John C.
    Diode Dynamics
    Sale ends at 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.
  17. Dec 7, 2022 at 12:57 PM
    Jev425
    Jev425 Well-Known Member
    Seattle Washington
    Do the C1 SAE get warm enough to melt snow? thank you
  18. Dec 9, 2022 at 12:45 PM
    Diode Dynamics
    St. Louis, Missouri
    Our SS3 in Sport and Pro power levels have been confirmed to melt snow and ice.
    However, we have not tested or had customer feedback regarding our SSC1 SAE Fog to melt snow or ice.
    According to our engineering team, the SSC1 Pro test in June 2021 in free air had temps around 85C on the housing.
    I wish we had more information on hand but will forward this request to review to our engineering team!
    Jev425[QUOTED] likes this.
  19. Mar 6, 2023 at 9:32 AM
    Diode Dynamics
    St. Louis, Missouri
    Our Spring Sale is LIVE! Visit our website to SAVE!
    ➡ Up to 15% OFF All Lighting Upgrades
    ➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
    ➡ 10% OFF Elite Series JL/JT Headlights
    ➡ Free US Shipping on any order over $300!
    Click HERE to shop your ride!
    John C.
    Diode Dynamics
    Sale ends 11:59 p.m. CST on Monday, 3/13/2023. Cannot be combined with other coupon codes. Excludes items with pre-order status.
    CttAznRanger likes this.
  20. Mar 10, 2023 at 11:01 AM
    Diode Dynamics
    St. Louis, Missouri
    ⌛THE CLOCK IS TICKING... ⌛
    NOW
    is your chance to SAVE up to 15% sitewide on your favorite Diode Dynamics LED lighting products.
    Up to 15% OFF LED Lighting Upgrades
    CLICK HERE TO SHOP NOW
    Did you know?
    You can find all of the products we offer for your vehicle using our vehicle finder tool! Simply enter the year, make, and model.
    SALE EXPIRES 11:59 P.M. MONDAY, MARCH 13TH, 2023.
    Discounts cannot be combined with other offers or any previous orders. Excludes items with pre-order status.
