SSO hybrid bumper install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by T’s16Taco, Mar 11, 2020.
  1. Mar 11, 2020 at 8:33 PM
    T’s16Taco
    T’s16Taco [OP] New Member
    Trav
    16’ limited Taco
    ARB RTT, ARQ4WD 180 awning, ICON Stage 4 lift, SPC UCAs, SSO slimline hybrid bumper w/ stage 2 high clearance.
    I’m new on this forum, Im asking for some help and input.
    I will be installing my bumper soon it’s a SSO Hybrid and If I purchase a Warn Powerplant dual force HP 9.5 winch (with a built in compressor) will I have the clearance behind the grill? I’m expecting modifications but has anyone seen this work? Or should I go a different route with the winch and on board air?
  2. Mar 11, 2020 at 10:19 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    There's no way that's gonna fit behind the grill. Will that even fit in the SSO bumper itself?
  3. Mar 12, 2020 at 3:51 PM
    T’s16Taco
    Trav
    16’ limited Taco
    That’s why I’m asking. I’m not sure. I just wanted input before I pull the trigger.
  4. Mar 12, 2020 at 3:59 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    My best guess is no way in hell. The zeon 10S platinum barley fits, IIRC.
  5. Mar 12, 2020 at 4:58 PM
    calebc
    calebc Well-Known Member
    From what I've seen, the winches that don't have the ability to have the remote control module, you have to remove (cut) the lower bracket. So you can be sure that will have to happen for that. However, if it's deeper than a standard winch (I haven't looked at any dimensions) then I don't see it fitting at all. If it's all just taller, then you might be able to fit it. With that said, why would you want your compressor mounted in a bumper that you can't hardly access? Even with the access holes, it would be a tough reach, or you could go from up top but that too will be a tough reach. I think there's either better bumpers (if you're set on the winch) or better winch/compressor combos if you're set on the bumper.
    T’s16Taco[OP] likes this.
  6. Mar 12, 2020 at 8:14 PM
    T’s16Taco
    Trav
    16’ limited Taco
    I appreciate the input. It would be difficult to access. I’m going a different route.
