SSO Slimline vs C4 Lo-pro vs Stingray Lo-pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Frogsauce, Dec 30, 2016.
  1. Jun 2, 2017 at 5:03 PM
    #161
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    I thought i read somewhere that one of these bumpers wont work or line up nicely if the truck is lifted, or was that something else completely?
  2. Jun 2, 2017 at 5:31 PM
    #162
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    If you have a body lift, none of them will
    shackley likes this.
  3. Jun 2, 2017 at 5:41 PM
    #163
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    That is such a clean look. That's the one I'm doing.
    TWTaco[QUOTED] likes this.
  4. Jun 17, 2017 at 9:30 PM
    #164
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I have read through all nine pages and am leaning towards the SSO. What winches are you guys using and rope or cable?
    TWTaco likes this.
  5. Jun 18, 2017 at 6:39 AM
    #165
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    RobP62 and TWTaco like this.
  6. Jun 18, 2017 at 6:50 AM
    #166
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Got that SSO at 25% off in the recent group buy.
    tcjacado likes this.
  7. Jun 18, 2017 at 7:07 AM
    #167
    M1Awolf
    Rob
    Montana
    Sorry if this has been asked already but which one requires the least amount of cutting on the bumper cover?
  8. Jun 18, 2017 at 7:33 AM
    #168
    Marbleyard
    Virginia
    2019 4Runner Pro
    I think SSO but it looks to be the most tedious. All of them have a no going back cut.
  9. Jun 18, 2017 at 9:37 PM
    #169
    TWTaco
    TWTaco Well-Known Member
    Dave
  10. Jun 19, 2017 at 7:19 PM
    #170
    C4 Fabrication
    C4 Fabrication Well-Known Member Vendor
    Caleb
    South Dakota
    07 DCLB Sport
    2" lift, 285/70/17 BFG TA KO2's, baja bumper, bedrack with swing out, CVT RTT, Leather interior, heated seats, JBL, remote start, K&N intake, Hood Scoop LED lightbar mod.
    All of them pretty much require about the same amount of cutting. The main difference between ours and the others is that our bumper is designed to cover the edges of the cut area instead of fitting inside the cut area. This leaves a much nicer looking finish and doesn't require the tacky looking rubber edging to fill the gap between plastic and steel bumper.
  11. Jun 19, 2017 at 7:26 PM
    #171
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
  12. Jun 19, 2017 at 7:31 PM
    #172
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Just pointing out the differences between ours and the others when it comes to fit and finish.
  13. Jun 20, 2017 at 3:05 PM
    #173
    TWTaco
    Dave
    But you left out you do cut out more of the plastic then you do with SSO slimline just pointing the difference's in the extra cutting! You cant go wrong with either one!
  14. Jul 20, 2017 at 10:28 PM
    #174
    bigtotoro
    bigtotoro Well-Known Member
    2017 Tacoma TRD Pro, Barcelona Red
    Does anyone have experience using the TRD Pro skid plate in conjunction with one of these 3 bumpers?
    ShemRahBuck likes this.
  15. Jul 21, 2017 at 6:21 AM
    #175
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Pretty sure @RelentlessFab confirmed they will work fine
  16. Jul 21, 2017 at 2:27 PM
    #176
    TWTaco
    Dave
    Fits no problem.
    RelentlessFab and ShemRahBuck like this.
  17. Jul 21, 2017 at 4:49 PM
    #177
    bigtotoro
    I'm hoping the Relentless bumper works, as I really want the winch opening to be perpendicular to the ground. But their website says "TRD Pro skid plate not yet confirmed."
    I have to run a front plate and I don't like the look of an angled plate. I'm not sure if a flip-up plate mount would be strong enough to hold the plate vertical out from an angled surface or if aerodynamic drag would push it flush.
    Good to know the SSO is a backup option. Thanks! If I go that route I might be asking you for help with a plate mount similar to yours. How is it holding up?
  18. Jul 21, 2017 at 4:53 PM
    #178
    TWTaco
    Dave
    Good no issue's.
    RelentlessFab likes this.
  19. Jul 21, 2017 at 4:57 PM
    #179
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    If you have ours and have some pics that would be great! :thumbsup:
    Edit: looks like you have a different one, but if the TRD skid mounts similar to the regular factory skid it shouldnt be an issue.
  20. Jul 21, 2017 at 5:01 PM
    #180
    RelentlessFab
    Eric
    Sparks, NV
    SixthSnail likes this.
