!st gen love, bed supports
Discussion in '1st Gen. Tacomas (1995-2004)' started by bldegle2, Mar 20, 2017.
  1. Mar 20, 2017 at 7:21 AM
    bldegle2
    bldegle2 [OP] OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Love the bed support idea for 2nd and 3rd gens. I found several alternatives for 1st gens on Ebay.
    Although not quite as beefy as the Bentrodders unit, they will fill the bill. Links below, several sizes are available...I only listed two links, I figure one can do their own search on Ebay. Obviously some drilling will be required...
    http://www.ebay.com/itm/391289868527?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
    http://www.ebay.com/itm/351225671788?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
    Enjoy...
    I am ordering a set today once I determine the correct dimensions...
    Over and out....
    DustStorm4x4 and ChadsPride like this.
  2. Mar 20, 2017 at 10:40 AM
    Croth51
    Croth51 Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    Hmmm bedsupports you say...
  3. Mar 20, 2017 at 10:55 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I thought the reason for bed supports for the 2nd gens is because they actually need them. If you apply load to the bed rails the bed can bend. While with 1st gens it is not needs so there is no product to solve a problem that doesn't exist.
    Feel free to correct me if I'm wrong. Which happens often so no big deal.
    Thanks for the link.
    DustStorm4x4 likes this.
  4. Mar 20, 2017 at 11:24 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    These are one of the products has came and gone. These were popular around the time tail gate nets came out, because everyone wanted that "pre runner" look. I'd venture to say your typical Tacoma owner has no need for these 1st or 2nd gen.
    otis24 likes this.
  5. Mar 20, 2017 at 1:30 PM
    bldegle2
    San Francisco, Ca.
    My bed sides at the rear have moved out (splayed) before, primarily from hauling heavy loads of 6' logs out from the back property over rough dirt roads. These puppies would have mitigated the problem for sure...
    I posted the links as the braces are not currently available for 1st gens...I can't be the only one who has had the problem, YMMV...I got tired of using my come along to re-straighten the sides...
    Whatever...
  6. Mar 20, 2017 at 1:37 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    With heavy loads tighten up a ratchet strap over it. Keeps mine from bending out. Also secures your load.
  7. Mar 20, 2017 at 2:33 PM
    otis24
    Mark
    California
    My idea of heavy load was not actually a heavy load. Lol
    I drove cross country with 1200 pounds of stuff in the bed of my truck with no problem BUT those weren't logs pushing on my bedside. That's a whole different story.
  8. Mar 20, 2017 at 3:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    1st gen beds are much sturdier that those that have come along later. However, our beds are still vulnerable to an extent.
    Over time, with the weight of an RTT on a bed rack any many miles of off-road jostling, I've begun to see one side of the bed being pushed out as evidenced by the gap between the tailgate and the tail light area of the bed.
    Not sure if these are the answer but the concept is a valid one.
  9. Mar 20, 2017 at 4:33 PM
    bldegle2
    San Francisco, Ca.
    Also bear in mind, after they bend the first time, the metal is weakened slightly, making it easier the next time a load or side force pushes on it...
  10. Mar 22, 2017 at 10:57 AM
    ROlla-Xrs
    ROlla-Xrs Well-Known Member
    Roman
    Elk,WA
    1st gen Trd Tacoma
    Either way looks like a cheap insirance if you haul stuff
