!st gen Tacoma torque spec?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Falkor1, Jun 29, 2016.
  1. Jun 29, 2016 at 1:22 PM
    Falkor1
    Falkor1 [OP] Well-Known Member
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    2,000 Tacoma rear axle with E-Locker.
    I can't seem to find the torque specs for the upper and lower control arms on my 95 tacoma. Aslo need the torque specs for my rack and pinion. Any help would be awesome!
  2. Jun 30, 2016 at 6:48 AM
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    This is out of my 2000 FSM:
    Tier Rod Ends: 59 ft lb
    Lower Ball Joint: 103 ft lb
    Lower A-Arm: 96 ft lb
    No 1 & No 2 Spring Bumpers: 17 ft lb
    Upper Ball Joint: 80 ft lb
    Upper A-Arm: 87 ft lb
    ABS Sensor Clamp: 17 Inch lbs
    what part of the rack and pinion?
    The Tie Rod ends are listed above. Are you looking for the mounting points for the rack itself?
  3. Jun 30, 2016 at 1:59 PM
    Falkor1
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    GA-3RZFE likes this.
  4. Jun 30, 2016 at 4:00 PM
    GA-3RZFE
    You are welcome.
    I have the manuals off that site, but couldn't find the link again. I ponied up for the printed FSM when I rebuilt my 2.7L.
    Falkor1[OP] likes this.
