Stability control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blazin11, May 9, 2017.
  1. May 9, 2017 at 12:59 PM
    blazin11
    blazin11 [OP] Member
    Ben
    Tollhouse, CA
    2000 Tacoma extra cab TRD 3.4 4x4 5 speed
    Installed bilstein 6112s on the 4th clip and light racing upper control arms in the front. Wheeler's 3 leaf pack in the rear with 5100s. After the alignment I drove it for a week on the stock tires and wheels and it drove fine. I live in mountains and even when I drove it aggressive it still drove close to stock. Then I put 265/75r16 bfg a/t on the factory wheels. As soon as I did that the stability control or what ever it is called started going off in the corners. I can't push the truck nearly as hard as I used to in the corners. Is there something that need to be recalibrated or reprogrammed?
  2. May 9, 2017 at 1:05 PM
    Pigpen
    Dan
    Northwest Montana
    Yaw sensor (VSC) needs to be recalibrated.
  3. May 9, 2017 at 1:29 PM
    blazin11
    Ben
    Tollhouse, CA
    Do I take it to the dealer?
  4. May 9, 2017 at 1:30 PM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
  5. May 9, 2017 at 1:33 PM
    blazin11
    Ben
    Tollhouse, CA
    Awesome, will try this when I get a chance. Thanks a ton.
    angrysam likes this.
