Stack it!! REAR
Discussion in 'Suspension' started by TACOsupremacy, Sep 18, 2011.
  1. Sep 18, 2011 at 11:56 AM
    TACOsupremacy
    TACOsupremacy [OP] Well-Known Member
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    So is it possible to "stack" suspension lifts period??
    I have 2inch AALs with no tsb in...i guess it finally settled in?? And now its actually about an inch lower than the front, yes i measured, flat ground etc...so i was wondering if i could jus throw like a 1inch block to level it, or i dont care if the rear is a little higher. I dont see why it cant be done but all thoughts and opinions please
    Thanks
  2. Sep 18, 2011 at 11:58 AM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Also I have the toytec coils up front set at 3inches
  3. Sep 18, 2011 at 11:59 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yeah you can do that, blocks arent the best for performance but it will work to just lift it another inch safely. Make sure to get new longer U bolts
  4. Sep 18, 2011 at 12:06 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    get ready for crazy axle wrap with blocks
  5. Sep 18, 2011 at 12:07 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Okay i thought so..I know it aint the best but i figure i could save some money that way :)
  6. Sep 18, 2011 at 12:09 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Damn new that was coming up haha...ok so what about stacking AALs?? I have a brand new 1 inch jus sitting :D
  7. Sep 18, 2011 at 12:27 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    You could flip the overload leaf for free
  8. Sep 18, 2011 at 12:40 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Serious?? wow never even thought of that :confused: I guess its safe and now i gots something to do today :D..
  9. Sep 18, 2011 at 12:52 PM
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    i could think of a million things to do,in HI which didn't include working on the truck
  10. Sep 18, 2011 at 12:53 PM
    malander
    max
    01 limited trd 4x4
    No problem. Idk how much lift you'll actually get but I know a couple people who have done it.
  11. Sep 18, 2011 at 4:09 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I wouldn't stack AAL's. I can't think of any really mechanical reason why not, but there's nothing keeping the bottom AALs aligned with the leaf pack.
    You can flip the overload but it only works if the arch of the leaf springs is less than the arch of the overload when you flip it. The problem with flipping the overload is it now puts the overload as part of the active leaf pack. The main leaf pack is thin leafs and flex well, the overload is 1/2" thick and is made specifically to not flex except under very heavy loads. In short, it will ride like a dump truck.
    If you can find a donor leaf pack, you can cut it up and make a leaf pack with more leafs. You could also get a new leaf pack but that's obviously expensive but would solve your problems.
