"Stacking" lifts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hutch301, Jun 18, 2012.
  1. Jun 18, 2012 at 5:35 PM
    Hutch301
    Hutch301 [OP] Member
    Not sure if this is a stupid question or not, but I would like to get y'alls opinion on this, so here it goes. I have a 2011 Tacoma 4 door 4x4. It has a 2.5 inch lift, spacers in the front and blocks in the rear. It's still not quite level yet, little nose heavy still. I'd like to get another inch out of it to get it level. So I was thinking of leaving the current lift on it and getting some 5100's in the front and adjust them to an inch to get that extra lift. What do y'all think? I was told by a guy at 4wheel parts that you shouldn't "stack" lifts. Any ideas on that? Or should I take out the spacers and put 5100's on it, and adjust them to the full 3 inches?
  2. Jun 18, 2012 at 5:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Bad idea. Lift right the first time.
  3. Jun 18, 2012 at 5:42 PM
    TacoLife08
    TacoLife08 Well-Known Member
    GA
    08 DC PreRunner TRD Rugged Trail SR5
    Camburg 4' Spindles, top plate spacers, 2" AAL, 285/75R/16 Terra Grapplers, Tinted Windows, Black Riveted Grille, Black Spyder Halo Healights/Tailights, FlowMaster 40 Exhaust, NFab Side Steps, Blacked out Skid Plate.
    ditch spacers and buy 5100's set at .85 with OME 884 coils. buy the shocks from DownSouthmotorsports.com and coils from toyteclifts.com
  4. Jun 18, 2012 at 5:45 PM
    Hutch301
    That's what I was thinking. Just trying to get 3 inches out of the front. Thanks guys.
  5. Jun 18, 2012 at 5:46 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Why preload 884's?? Just get 885's...
  6. Jun 18, 2012 at 5:48 PM
    Hutch301
    Real quick guys, what the heck is that [op] next to my name mean? New to this stuff
  7. Jun 18, 2012 at 5:51 PM
    Pugga
    Massachusetts
    Nope, 884s and 885s have the same spring rate. The 885s are just taller to provide more lift.
  8. Jun 18, 2012 at 5:51 PM
    TacoLife08
    GA
    op wants full 3 inches. unattainable with coils alone
    [OP] = Original Poster / Thread Starter
  9. Jun 18, 2012 at 5:53 PM
    Pugga
    Massachusetts
    Yes, it is... any of the adjustable coilovers will get you to 3" of lift, 886's will do the trick also but they'll be stiff as hell (and possibly put you over 3"), Procomp coils will get you there also. There are also custom length coils that, if ordered in the correct length, will get you to 3" of lift.
    If you're not going for adjustable coilovers, 885's with the top plates that come with the Toytec kit will get you to a full 3".
  10. Jun 18, 2012 at 5:54 PM
    TacoLife08
    GA
    you just proved what i said ...
  11. Jun 18, 2012 at 5:55 PM
    Pugga
    Massachusetts
    Re-read, I just disproved what you said...
  12. Jun 18, 2012 at 5:59 PM
    TacoLife08
    GA
    Was unaware 886's gave 3" of lift
  13. Jun 18, 2012 at 6:04 PM
    Pugga
    Massachusetts
    It's not a great idea if you have an unarmored Tacoma. They're much stiffer than 885's and taller but it's been done. They designed to maintain lift with an excess of 200# hanging off the front, like an ARB with a winch.
    Don't go by those heights listed on Toytec's website, they're not accurate at all.
  14. Jun 18, 2012 at 6:06 PM
    TacoLife08
    GA
    Eh, i cant argue that having not seen 886's on an unarmored taco
  15. Jun 18, 2012 at 6:11 PM
    Pugga
    Massachusetts
    There are better options out there to get to get to 3" of lift. 886's are very stiff, same with the Procomps.
  16. Jun 18, 2012 at 6:18 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    I know stacking is frowned upon but the only real negative is that you could bottom out the 5100's before the lca's make contact with the bumpstop. Maybe if you move the bumps lower it would help hinder the bottoming out and destroying everything.
  17. Jun 18, 2012 at 6:27 PM
    Pugga
    Massachusetts
    There's no good reason you'd use top plate spacers along with 5100's.
  18. Jun 18, 2012 at 6:58 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Maybe to get the height without the stiffness that you get when you pre load.
  19. Jun 18, 2012 at 8:02 PM
    Hutch301
    Will just the 5100's give me 3 inches of lift?
  20. Jun 18, 2012 at 10:36 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    What he said, the MOST you will see is maybe 2.75"
