"Stacking" lifts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hutch301, Jun 18, 2012.
  1. Jun 18, 2012 at 10:45 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    That's what i'm doing. I have Icon coilovers with 1/2 top plate. But i'm not 4x4, You'll also need to make sure you don't over extend your CV axles.
  2. Jun 19, 2012 at 4:40 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    1/2" plates won't cause any harm, using 2"+ top plates with 5100's just seems like a waste. If you want to use top plates that tall, don't bother with getting a ride height adjustable shock, you're paying extra money for a function you aren't going to use. That's why I said there's no good reason to use a spacer lift with 5100's.
    5100's will get you to 2.5" of lift +/-. You can then use the short top plates to get you the rest of the way to 3".
  3. Jun 19, 2012 at 4:53 AM
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    Get shorter rear blocks to lower the rear a little instead, it will be less risky than putting spacers on 5100s (which is a bad idea), and it will be cheaper too, you wont have to get new UCAs. Just tell people it has a 3" lift, and dont mention that it is really a 2.5" or 2.75" lift, no one will know the difference.
