Stage 2 clutch
Discussion in 'Performance and Tuning' started by 993rztaco, Jan 11, 2017.
  1. Jan 11, 2017 at 12:39 PM
    993rztaco
    993rztaco [OP] Member
    99 Tacoma small lift 31x10.50
    OK guys my clutch went out 237k miles, and I've just changed the master and slave cylinders. I went to look at a new clutch at KY Clutch, and they want 125 for a basic clutch or 200 for a stage 2. I've got the 2.7 on 31's is there any reason not to get the stage 2?
  2. Jan 11, 2017 at 7:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Torque holding capacity.
  3. Jan 13, 2017 at 4:08 AM
    993rztaco
    So your saying not to get a stage 2?
  4. Jan 13, 2017 at 4:10 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    You don't need stage 2. It will take more power but the trade off is worse feel. Not as smooth on engagement etc
  5. Jan 13, 2017 at 4:12 AM
    993rztaco
    Got ya, Im going to get the basic clutch and just get an upgraded pressure plate , and throwout bearing. Should be good for another 250k then trying to make it to the 500k club!
  6. Jan 13, 2017 at 4:14 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Yeah that's good. With a stock 2.7 the stage 2 is completely pointless
