Stage 2 clutch?
Discussion in '1st Gen. Tacomas (1995-2004)' started by shadillac1, Jan 15, 2019.
  1. Jan 15, 2019 at 11:37 PM
    shadillac1
    shadillac1 [OP] New Member
    Shad
    1997 Toyota Tacoma SR5
    3in lift
    What's up guys, I have a 1997 Taco SR5, it has a 3in lift to it and I use it as both my daily and offroad beast. Long story short the clutch is going to need replacing soon and I was wondering if I should go stage 2 or OEM.
  2. Jan 16, 2019 at 6:22 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    @shadillac1
    Stage 1 Excedy (or OEM if you have the money) would be my choice if I needed one.
    BTW, you may want to give more info such as engine size, mods to that engine, daily driver or off-road only, etc. Basically, why are you even considering a Stage 2 clutch.
  3. Jan 16, 2019 at 8:19 AM
    TACOLGY
    TACOLGY Well-Known Member
    Mark
    2003 Tacoma TRD SR5 DC
    Stage 2 all the way
  4. Jan 16, 2019 at 11:35 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Aisin or Excedy stock replacement and be done. For a DD/wheeler, you want the longest throw, softest engaging clutch as possible. It's no fun to wheel or sit in traffic with a super short throw from engaged to disengaged and a heavy pedal.
  5. Jan 16, 2019 at 12:00 PM
    1997tacomav6
    Denver
    Either way make sure you get the highest quality bearings possible. Throw out, pilot bearing.
    My OEM clutch I replaced 100,000 miles ago is working fine, but the throw out bearing is starting to make a lot of noise, guessing I will need to replace it which is almost the same work as a new clutch job.
    My OEM clutch before that was doing great at 250,000 miles until the pilot bearing took a dump and
    replaced everything because I was in there.
    Two of the three clutch jobs I have needed on my truck where failure from bearings.
  6. Jan 16, 2019 at 12:53 PM
    tony2018
    tony2018 Well-Known Member
    stage 5 is GOAT
  7. Jan 16, 2019 at 12:55 PM
    UnderFire
    UnderFire Well-Known Member
    Aisin stock replacement or LUK ceramic from Napa.
