Stainless Braided Brake Line Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoman45, Jul 17, 2024.
  1. Jul 17, 2024 at 6:44 PM
    tacoman45
    tacoman45 [OP] Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Hey folks - I tried to find a tutorial via the search bar on replacing the OEM rubber brake lines with stainless braided lines but came up empty handed.
    To those folks who've already done this mod to their trucks - which tutorial did you use to do the job? Hindsight is 20:20 - any things to watch out for when doing the swap?
  2. Jul 17, 2024 at 7:04 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Same process as replacing the rubber lines. It's not difficult, just make sure you have good line wrenches so you don't F up the flare nuts and have a bad day.
    tacoman45[OP] likes this.
  3. Jul 17, 2024 at 7:23 PM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    ^^ THIS
    - Spray the connecting fittings, bleeder screws, etc ahead of time so they break loose easy.
    - Get everything tools, supplies, drain pan laid out first.
    - As mentioned above, use good quality brake line wrenches (unless u want to round off the fittings) DONT OVERTIGHTEN during reassembly
    - Once you’re ready go for it and do the changeover quickly as you will be losing brake fluid while the lines are not connected.
    - Dont let the master cylinder run dry, bleeding them is PITA
  4. Jul 17, 2024 at 7:29 PM
    TacoTuesday1
    SD CA
    Don't really need a tutorial.
    The right tools and pre-emptive measures to make sure they loosen without stripping or seizing.
  5. Jul 18, 2024 at 1:22 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Also, bleed the brakes after the swap. But to reiterate as the poster above said, don't let the BMC run dry.
  6. Jul 18, 2024 at 11:50 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    The only thing odd I remember was with the rear brake lines. Seems the OEM lines have different sized holes in the brackets. The new SS lines were both the same and I had to file out one of the brackets.
  7. Jul 19, 2024 at 10:36 AM
    DailyTacoMD
    Jeremiah
    Not sure if it is standardized but I did not have fit issues with the fronts when I swapped them. I bought Stoptech lines from RockAuto and there were no issues for me, however I only did the fronts so I can’t speak on the rears
