Stainless Brake Line Install Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011Barcelona, Oct 9, 2011.
  1. Oct 9, 2011 at 2:37 PM
    2011Barcelona
    2011Barcelona [OP] Member
    Doug
    Forked River
    2011 DC TRD Sport SB V6
    I finally installed the set of "Group Buy" lines that I bought several months ago, and ran into a few small issues that I thought I'd share.
    Stock length lines in my stock truck, just looking to improve the feel a bit.
    The rear lines fit too loose in the brackets using the stock retaining clips, so I took some 1/2" stainless washers and opened up the holes to 16mm to take up the slack.
    As delivered, the fittings on the front lines won't fit into the stock brackets. After removing .010" from the outer hex portion of the fitting, I was able to get them to fit into the brackets. I used my lathe, but if you just file down the tips of the outer hex a bit, then they'll fit.
    And there's no way to securely retain the front lines using just a single stock retaining clip. I ended up using both of the stock retaining clips to secure the lines nearest the calipers, and a single thicker clip, that I happened to have, on the frame ends. I plan to purchase 4 more stock clips in order to double clip that end as well.
    srdoublecab2.7 likes this.
  2. Oct 9, 2011 at 2:46 PM
    mrw3685
    mrw3685 Well-Known Member
    TX by way of KS
    08 Prerunner TRD
    Maxtrac Spindles, Bilstein 5100s all around, set at .85, Allpro Expedition Leaf Pack, Procomp 7036 17x9, w/Nitto Trail Grappler 285/70/17, Extended Steel Braided Brake Lines, Red-Line Hood lift, Relocated Trailer Connection, Trimmed Front Fender.
    I didn't do exactly what you did, but to say the least, I almost would have rather paid a little extra money for lines that fit in like stock vice get a good deal on these, and have to jerry rig the hell out of them to fit properly. They were definately a bit of a pain.
  3. Oct 9, 2011 at 2:46 PM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    Thanks for the write-up. I have been avoiding putting mine on too for the same reason.
  4. Oct 9, 2011 at 4:16 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i had mine installed by a shop but, they seem to be doing just fine.
  5. Oct 15, 2011 at 1:47 PM
    2011Barcelona
    Doug
    Forked River
    FYI, The p/n for the brake line clips is 90468-A0007, $1.57 ea. at my local stealership.
  6. Oct 15, 2011 at 11:05 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Whoa, got a lift inside your garage? Badass
    Anyways, I didnt know there were any issues with those. I have mine sitting in the closet for months now. Just never got around to getting them installed. Since I dont really know how all the parts work or install, I dont understand what the issues are. :eek:
    Is the circled item the brake line clip?
  7. Oct 16, 2011 at 2:50 AM
    2011Barcelona
    Doug
    Forked River
    No, you can see the brake line clips doubled up in the fourth pic that I posted above and circled in red below.
  8. Oct 16, 2011 at 4:51 AM
    Gordon-Gekko
    Gordon-Gekko Member
    Fort Lauderdale, Florida
    08 2.7 PreRunner SR5
    Ivan Stewart Wheels, RollBak Tonneau, Hellwig Rear Sway Bar, URD Short Throw Shifter, LC Engineering Header, Fumoto F-103, WT SW Deflectors
    Any noticeable difference in pedal feel?
  9. Oct 16, 2011 at 6:37 AM
    2011Barcelona
    Doug
    Forked River
    I believe so, but it could be wishful thinking. However, my wife even noticed a difference.
  10. Nov 27, 2011 at 2:10 PM
    2011Barcelona
    Doug
    Forked River
    A follow-up on the "feel" issue.
    There is so much of an improvement, that either the factory doesn't know how to properly bleed brakes, or the stock rubber lines must be balloons. My wife still mentions it everytime she drives the truck.
    And I finally got around to "double clipping" the upper end of the front lines. :cool:
  11. Nov 27, 2011 at 5:18 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    on the group buy thread I posted my install. i rebent my retainer clips.
  12. Nov 27, 2011 at 5:31 PM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    Funny i see this today. I did this over the weekend and ran into some of the same things as everyone else, except my fronts fit fine, no filing/lathing for me. I also just bent the stock clips a bit more to hold it in. Worked fine. The only other problem i faced was that for some reason on of my back lines had 2 different sized fittings. Guess he just put on the wrong one when making them. Pedal feel.. I guess its working better? Hard to say only been a day. Nothing night and day to me.
  13. Nov 27, 2011 at 5:51 PM
    WATacoRider
    TRD Sport 4x4
    I dont understand what the clips are suppose to do? Shouldn't the line already be held in place by the bracket that the clips, clip onto?:confused:
  14. Nov 27, 2011 at 5:54 PM
    06RadiantRed
    CA-Bay Area
    Go take off one of your clips and you will see why they are there. They are basically springs that hold the lines on the brackets.
  15. Nov 27, 2011 at 11:27 PM
    sytfu510
    Alex
    Bay Area
    I had the same issue with the rears, had different sized fittings.
  16. Nov 28, 2011 at 9:38 AM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    How long are these brake lines from end to end? Are they for stock height trucks or lifted?
  17. Nov 28, 2011 at 10:05 AM
    06RadiantRed
    CA-Bay Area
    I specified mine, told him that i had a 3"~ lift. Mine have more slack than stock in the rear, altho i did not measure them.
  18. Nov 28, 2011 at 11:11 AM
    sytfu510
    Alex
    Bay Area
    I have a 3" lift, the lines were 1" longer than OEM.
    Here's a pic of the rebent clips:
  19. Dec 15, 2011 at 9:30 PM
    WATacoRider
    TRD Sport 4x4
    So concerning the rear lines. What do the wrong plugs look like? I'm hoping mine are fine.
    Also, do you have to use those washer spacers in the rear? Or can you "double up" on the brake clips?
    How many additional clips are required to complete this hack job? Are the clips standard? Or is it recommended to buy the OEM ones?
  20. Dec 15, 2011 at 9:36 PM
    2011Barcelona
    Doug
    Forked River
    For the rears you could probably just bend the clips a bit (as posted above by sytfu510), I honestly didn't think of that when installing mine. :eek:
    I used 4 extra clips in the front, and wanted to use stock clips, which are cheap enough IMHO.
