Stainless Steel brake lines with TRD pads installed
Discussion in 'Performance and Tuning' started by Street Runner, Jul 12, 2013.
  1. Jul 12, 2013 at 12:16 PM
    Street Runner
    Street Runner [OP] Active Member
    Tampa, FL
    TRD Sport BSP
    TRD CAI, JBA LT's, TRD CatBack, Hellwig Sway Bars, SS Brake Lines
    Hey guys, here is my review of the Goodridge G-Stop Brakeline Kit. This is the first step for me in an effort to upgrade the braking power of my truck. The kit comes with 2 front and 2 rear brake lines. I reused the factory clips that hold the lines to the mounting brackets because they seemed more robust than the ones that came in the kit. The front lines went on with no problems but the rear lines were a total PITA! I would recommend that the novice mechanic might want to pay a shop to install the rears. The reason I say this is because the point where the rear lines connect to the hard steel lines is located above the driver rear tire inside the frame rail right under the bed of the truck. There is no way to see what you need to do and the location is extremely difficult to access. Putting the truck on a lift and removing the spare tire probably would make things easier. I did it the hard way but I got it done. I put in new fluid and bled the the brakes with no issues. I inspected my pads and rotors and they still look good with 65k on them so I will wait awhile to upgrade them. I have been driving with the new lines for a few months now and I like them, the pedal has a more firm performance feel. I hope this info helps someone out there.
    I purchased the Goodridge G-Stop Brakeline kit from Tirerack for $118 + shipping.
    http://www.tirerack.com/brakes/brak...+TPMS&autoYear=2005&autoModClar=2wd+Prerunner
    Sorry I forgot the pics of the front lines. I will try to post some up soon.
  2. Jul 12, 2013 at 3:49 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    I bought this kit a few years ago and had major issues getting the fronts on...the threads didnt match up and eventually forced them on. Never did the rears because of the headache. I Do like them though
  3. Jul 13, 2013 at 1:57 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    I bought the same brand due to lifting. Bought two inch extended but in hind-sight maybe should have gotten even longer. S/S is always a good way to go. Surprised about the thread thing in post 2, maybe a fluke mixup?
  4. Mar 27, 2014 at 12:28 PM
    Street Runner
    Tampa, FL
    TRD Sport BSP
    I got to 75k miles and decided to go ahead and have my rotors turned and I installed the TRD brake pads from trdparts4u.com. I am very happy with the stopping power of these pads but I am not so thrilled with the brake dust that now accumulates on my front wheels after only one week of conservative driving. I guess that is the trade for more stopping power. These pads do work great and do not make any noise. I would recommend them if you do not mind the dust. Pedal feels very solid. Truck stops quick. :)
  5. Jun 11, 2014 at 5:34 AM
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    Good review on these! I'm looking to upgrade my brakes soon as well :popcorn:
  6. Jun 11, 2014 at 5:39 AM
    fenderpicks
    fenderpicks Well-Known Member
    Man i hate changing these brake lines
    One time my Hard brake line nut got stripped, and had to replace the entire line from the master cylinder to the wheel.
  7. Jun 11, 2014 at 8:24 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Flare nut wrench or Knipex parallel pliers will prevent the rounding of the nuts. :thumbsup:
    TRD brake pads are VERY dusty pads. Work well, but damn.
  8. Jun 11, 2014 at 12:25 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    who cares? because race truck...
  9. May 10, 2016 at 6:29 AM
    D4D Hilux Dude
    D4D Hilux Dude Well-Known Member
    Darren
    Arvada, CO
    2011 4x4 Double Cab TRD Offroad
    TRD Supercharger TRD Catback Exhaust Ziebart Rust Proofing Additional Bed Ties 2012 Indicator side mirrors
    Reviving an old thread...
    I recently bought the same goodridge kit that the OP's link points to (goodridge 21155) and I have a question... are they supposed to come with little washers that fit inside of the hose fitting before attaching them to the truck's hard lines? The little plastic bag has only C clips for holding the lines in place and I was wondering if the lines came with the thin washers.
    I read somewhere (cant remember where or if it was even for the goodridge lines) to make sure the washers were lines up properly or else they will leak.
    Thanks
  10. May 10, 2016 at 10:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No idea. However, the washers should also be on the OEM caliper. You can try to reuse those, or purchase a new set. I know that Jegs and Summit Racing sells them. Yours would be for a 10mm bolt.
  11. Jul 31, 2016 at 12:04 PM
    TX444
    TX444 Did you tell them they were the Lord's chips!
    Diego
    victoria,texas
    Silver '11 DCSB 2wd Pre Runner
    I ordered the same kit from tirerack as well and the rear lines didn't fit at all! So I didn't feel like haggling and didn't send them back since the front ones were already on. I used Autozone premium ceramic pads and kept the stock rotors for now, I bought them to enhance my towing capabilities which I haven't towed anything yet, other than that, they stop on a dime and give you change! Love em!
