Stainless steel sliders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by uncle eddie, Jul 14, 2021.
  1. Jul 15, 2021 at 10:44 AM
    #41
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    If you're doing fill plates, bolt ons might be a better option. Especially since the plates are more so for sliders used as a step. As you can see, I use ladder grip tape for the ice and rain.
    You're right. Too many small places to clean up.
  2. Jul 15, 2021 at 10:55 AM
    #42
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    316 Stainless sliders would be extreamly expensive and the only option for SS if you was them to stay looking that way. It's not something we would ever do here. At todays metal pricing any good shop that works with SS making a quality one off set would be well over $2500 to fabricate 316 bolt on sliders and that's being frugal.
    outxider, blu92in99, DG92071 and 4 others like this.
  3. Jul 15, 2021 at 11:52 AM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Thick aluminum tube or pipe, and bolt on. Light and cheap. Then AL diamond plate. Fancy fancy
    DG92071 likes this.
  4. Jul 15, 2021 at 1:13 PM
    #44
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So if armorers could make a steel suit last for hundreds of years, through the annealing, quenching, and then tempering process, then that's what we're missing here for the mild steel sliders. Strong, ductile, and granular structure which resists granular corrosion.
    Just need a huge furnace, water tub, and oil tub. Piece of cake. ;)
    DG92071, 6 gearT444E and Jimmyh like this.
  5. Jul 15, 2021 at 7:43 PM
    #45
    uncle eddie
    uncle eddie [OP] Member
    Wow, such a discussion! Almost like hitting a nerve. So many relevant points being made by all, it must be why we love this forum stuff. Allow me to address some of the things written. Where I live, road crews use sand with salt mixed in, mostly dirt roads. Last thing I want to do is wash out my undercoating in the middle of winter. I wash out salt and sand in spring and re-apply since mud season is salty mud for a few weeks. Wash out and re-apply in late fall. Just seemed a good idea to not put oil on a set of sliders intended to be stepped on.
    Torspd and DG92071 like this.
  6. Jul 15, 2021 at 8:14 PM
    #46
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Another option is to have Line-x applied to the sliders. The Line-x will encapsulate the sliders. Mine are holding up well but I do not off Road nor do I get the salt you do.
  7. Jul 15, 2021 at 8:56 PM
    #47
    DG92071
    DG92071 Well-Known Member
    Yes I'm with you on this one. Thick aluminum.
    Fully polished 316 stainless would look trick but the real trick would be paying for them haha material costs are nuts right now - if you can find the material.
    Torspd[QUOTED] likes this.
  8. Jul 16, 2021 at 1:07 AM
    #48
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    If you make it out
    If you really want to make them stainless, 316/316L will do the trick. Lower 300 series stainless don't hold up to salt spray as well. 316/316L is weldable, to itself and carbon steels as well.
    That being said, if I were going to build sliders, I would go with chromoly (someone mentioned 4130 earlier which I've worked a lot with and is a great steel for rigid structures like sliders) and then just be prepared for some light standing and 30 minutes with a rattle can on the spring. You could even use mild steel which would be cheaper (and heavier).
  9. Jul 16, 2021 at 6:18 PM
    #49
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yeah....but then you live in California.
    ace96 likes this.
  10. Jul 16, 2021 at 6:59 PM
    #50
    JPT4x4ac
    JPT4x4ac Well-Known Member
    Jon
    Broadalbin , NY
    2012 Grn Tacoma AC 2.7 MT
    I like shiny! Schedule 40 304 stainless pipe will work fine. I’m in upstate New York. Pushbar has been on my truck since 2015 and held up to an 80mph head on deer strike. I polished it to mirror finish and used a boating product called shark skin, it’s about time I give it another coat.
  11. Jul 16, 2021 at 7:03 PM
    #51
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Sand blaster will get any nook and cranny. Also, I work on boats, in my experience it's called stainless and not stain-never because nothing is 100%, and small nicks or gouges in stainless and it'll rust some
  12. Jul 17, 2021 at 5:03 AM
    #52
    geekhouse23
    Couldn't pay me to live there. I live one state over from you...
    9mmMike likes this.
  13. Jul 17, 2021 at 6:24 AM
    #53
    DG92071
    I've had enough with the ignorance of California's qualities. See ya'.
  14. Jul 17, 2021 at 6:32 AM
    #54
    winkel
    Corydon, IN
    Yeah, 316 would be overkill for this application. 304 would be fine. 316 has added moly to make it more corrosion resistant. It's considered a marine grade and is what is used for any of the stainless jewelry that reputable companies make. The human body is a hell of a corrosive environment too.
    304 would hold up great.
    Torspd likes this.
  15. Jul 17, 2021 at 8:46 AM
    #55
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pics?!
  16. Jul 17, 2021 at 9:00 PM
    #56
    Skynet Surfer
    Skynet Surfer Well-Known Member
    Dis
    15 DC v6 SR
    Hood struts Weathertech floor mats Roll n lock bed cover With custom Yakima rack over the bed Poploc tail gate Bed mat Retrofit source led fog lights Hitch and or 4 pin wiring Or just random small crap!
    Stainless isn't a strong metal for this kind of tubing. It will likely bend or show damage a DOM tunnel won't show. So while I understand the rust issues. I can't understand using this metal with how soft it tends to be.
  17. Jul 17, 2021 at 9:04 PM
    #57
    TacoTuesday1
    SD CA
    there's a lot of mental and financial rust there
    do a good job painting sliders
    unbolt and re-paint in 10 years
    /thread
    geekhouse23[QUOTED] likes this.
  18. Jul 17, 2021 at 9:25 PM
    #58
    j8food
    j8food Well-Known Member
    Jay
    2009 Tacoma TRD Off Road
    Has anyone mentioned how heavy stainless is?
  19. Jul 18, 2021 at 5:52 AM
    #59
    DG92071
    Soft? LOL
    Yes
  20. Jul 18, 2021 at 7:52 AM
    #60
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    A good paint job, rust protectant coat on the mounting legs/frame side, and maybe some diy mini mud flaps at the front and rear if really super concerned, and they’d be good to go. Touch up is as easy as a little wire wheel and rattle can.
