Stainless Steel vs Ceramic Coated!?!?
Discussion in 'Performance and Tuning' started by Peewee1618, Sep 13, 2012.
  1. Sep 13, 2012 at 2:55 AM
    Peewee1618
    Peewee1618 [OP] Active Member
    Texas
    2001 SR5 4WD
    AFE Air Intake with a PRO Dry-S filter, AFE throttle body spacer, Borla exhaust system, Full Donahoe suspension lift kit (coilovers and add a leaf), HID Light conversion kit, JBA cat-forward headers.
    Im looking into putting some headers into my 01 Tacoma but i noticed there is a big difference in price for stainless steel headers compared to ceramic coated. Is there really a difference?! How will it affect performace? :confused:
  2. Sep 13, 2012 at 2:58 AM
    Peewee1618
    Texas
    2001 SR5 4WD
    All i know is that ceramic gives off less heat but i dont know what difference it makes in performace
  3. Sep 13, 2012 at 3:39 AM
    Peewee1618
    Texas
    2001 SR5 4WD
    ok ill guess ill just go stainless steel, i mean afterall it is my daily driver, that way the headers can last longer.
    Thank You
  4. Sep 13, 2012 at 5:51 AM
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    what are the coated header made out of?
  5. Sep 13, 2012 at 11:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If you get un ceramic coated headers, make sure they are 304 stainless.
    For that matter, like Darthyota asked, find out about the coated ones as well.
    If the non coated ones are 409 mild steel, they will rust if not coated.
  6. Sep 13, 2012 at 11:17 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
  7. Sep 13, 2012 at 11:36 AM
    Darthyota
    Alberta
    Blown BSP X-Runner
    the only problem with wrapping headers is that the wrap will absorb any fluid that's spilled on to it which can be a significant fire hazard not to mention that if you rub up against it while working under your truck it will irritate you skin
  8. Sep 13, 2012 at 12:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    One thing to combat is silicone spray. You can purchase that at Home Depot, for much cheaper than say DEI.
    That is what I do to mine, to help it last. Helps to keep the moisture out.
  9. Sep 13, 2012 at 7:45 PM
    Peewee1618
    Texas
    2001 SR5 4WD
    The non coated ones are 409 steel, here is the website for the following JBA headers on Autoanything.com
    http://www.autoanything.com/exhausts-mufflers/61A2280A0A0.aspx
  10. Sep 13, 2012 at 7:47 PM
    Peewee1618
    Texas
    2001 SR5 4WD
  11. Sep 13, 2012 at 8:13 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Very nice! I do recommend getting them coated at some point, if you don't at the time of purchase.
    That will be a heck of a nice bumpage in power!
  12. Sep 13, 2012 at 8:32 PM
    Peewee1618
    Texas
    2001 SR5 4WD
    I ended up getting the stainless steel ones, ill post up pics once they come in. I got them fairly cheap too. The stainless steel ones were 478 on Autoanything.com plus i used a 15% off coupon (coupon code: PBEB3) and it brought it down to 407. :)
  13. Sep 13, 2012 at 8:33 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Damn. That is being smart about it right there. :thumbsup:
  14. Sep 14, 2012 at 5:26 AM
    Darthyota
    Alberta
    Blown BSP X-Runner
    304 ss ?
  15. Sep 14, 2012 at 11:00 AM
    Peewee1618
    Texas
    2001 SR5 4WD
  16. Sep 22, 2012 at 12:21 AM
    Peewee1618
    Texas
    2001 SR5 4WD
    They're finally here!
  17. Sep 22, 2012 at 12:28 AM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    407?! so tempting
  18. Sep 22, 2012 at 1:41 AM
    Peewee1618
    Texas
    2001 SR5 4WD
    yup, 407 out the door with free shipping and handling as well.
  19. Sep 29, 2012 at 10:23 AM
    Peewee1618
    Texas
    2001 SR5 4WD
  20. Sep 29, 2012 at 10:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sounds good mate. How do you like the new feel and sound?
